will not start now - FFCars.com : Factory Five Racing Discussion Forum
Old 08-02-2006, 03:35 PM   #1 (permalink)
BobNealy's Avatar
Unhappy
Ok I have the 351w 400hp from the engine factor with 70 miles on it It was running ruff and rich. When I went to adjust the mixture it died and now will not start. It is getting spark and gas. Everything (timing, fuel pressure …..)Looks to be adjusted right where should I look next?
GTM Gen 2 on hold to many houses to buy
A non-doner IRS 351 black with gray strips
BobNealy is offline
Old 08-02-2006, 03:45 PM   #2 (permalink)
change the plugs and give it another try.
Still spending...
License plate \"HAR2(hand)DL\"
Mods out the butt
Kit arrived on 6/10/05
Paint done 3/27/06
Jester is offline
Old 08-02-2006, 03:48 PM   #3 (permalink)
BobNealy's Avatar
what should the plugs be set at
BobNealy is offline
Old 08-02-2006, 03:56 PM   #4 (permalink)
Carb, EFI, or what?
Asp
Want: FFR MKIII Roadster, IRS
Have: '68 Fairlady Roadster project car
Drive: Scion XB
Problem: Too many projects, too little time!
psomdecerff is offline
Old 08-02-2006, 05:32 PM   #5 (permalink)
BobNealy's Avatar
jester
Thankyou changed the plug starts right up Also would like to thank Robert and Matt at the engine Factory for taking a we will do whatever it takes attude to get you up and runing you can not ask for more then that.
BobNealy is offline
