Hi guys,
My serp belt is squeaking at times, but not all the time. If I'm at idle, and rev it up around 4K, it squeaks pretty bad. Same happens when the car is cold and about to die (no choke), I'll give the throttle a little stab to keep it alive and it squeks there too. This belt only has 1400 miles.
If your using the stock auto tensioner there should be markings on the front of it to let you know if the belt is stretched.
Also check the belt routing!
__________________ Every Shelby built after May 10, 2012 are not original Shelby’s or Shelby continuations, but are Shelby replicas.
Sorry to burst your bubble.
"If someone doesn't comply with the federal registry of their gun, will it be illegal, or will Democrats insist on calling it 'undocumented'?" B.C. 1/23/13
Shep Qualified old guy. Dad of Willspeed. 89 Donor.Mk. III IRS, 302,equal length headers, 65 mm throttle body 77 mm MAF,Kenne Bell Supercharger,Levy bump steer kit & Koni Shocks.Finish line nudge bars, Cobra Earl Trunk, FFMetal batbox and footbox,APE hardtop, Vintage A/C, Lucas windscreen washer. Detailed, painted, graduated. Driving, adding stuff.
I had that problem with my March pulley set up. I have just the basic alternator,crank pulley and water pump. I customized the set up a bit (didn't like the alternator sticking up around the valve cover hight). I didn't have enough surface area of the alternator pulley making contact with the belt surface. I took a
little bit of the peaks off the pulley and no more squeal.
You can also try a Gator belt from Goodyear,
believe Summit has them.
Good luck
If people concentrated on the really important things in life, there'd be a shortage of fishing poles.
On the brand cars I work on some of the models use the Ac comp. or PS pump to adjust tension.It is scary how tight we have to make them to avoid a squeal a week or month later.Tighten it up!
