Fuel Injection Issue - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Fuel Injection Pit Road
Old 07-30-2012, 06:51 PM   #1 (permalink)
sgspeed's Avatar
My car has been off the road since 2009 and now i am finally putting it back together.
The engine is out of an 89 mustang gt with the original ecu and harness. I rewired the ignition and the dash, and I connected all the connections as before, hot to the fuel pump, hot to the eec power relay hot in run to the oxygen sensors, hot in run or start to the ignition coil and TFI module as well as the starting system connection to the TFI.
I have a spark. The engine is timed correctly.
I have 40 pounds of fuel pressure.
The engine will not start because it appear that the injectors are not being activated. I pulled one of the plugs and there is no trace of fuel.
I know that I am missing something very simple, but for the life of me I cant see it not.
Any help would be appreciated
Shep
Qualified old guy. Dad of Willspeed. 89 Donor.Mk. III IRS, 302,equal length headers, 65 mm throttle body 77 mm MAF,Kenne Bell Supercharger,Levy bump steer kit & Koni Shocks.Finish line nudge bars, Cobra Earl Trunk, FFMetal batbox and footbox,APE hardtop, Vintage A/C, Lucas windscreen washer. Detailed, painted, graduated. Driving, adding stuff.
sgspeed is offline   Reply With Quote
Old 07-31-2012, 01:00 AM   #2 (permalink)
Seagull81's Avatar
Did you check the harness for power at the injectors? If they had fuel in them when the engine sat up for a long time they could be varnished up and not working because of it. Just a thought.
Texas Cobra Club-Austin
FFR3542K, 347 C.I., Holly Systemax EFI, T-5, Modified 4-Link, Miata Front Sway Bar, Red with White Stripes
Seagull81 is offline   Reply With Quote
Old 07-31-2012, 03:40 AM   #3 (permalink)
A Noid light will tell you if the injectors are being fired by the ECU.
Old 07-31-2012, 12:09 PM   #4 (permalink)
EFI Rules and Carbs Drool
Arrowhead's Avatar
I'd vote for plugged injectors also. Had this happen on a couple of occasions when engines sat for long periods. Just pop them out and spray carb cleaner into them the best you can. I would also test each one with 12v from a battery to hear the "click" of them opening. You can even do that while they are still installed. Also double check the power from the ECU as Bob said.
FFR '33 #78
Picked up 5/30/09
Old 07-31-2012, 01:00 PM   #5 (permalink)
sgspeed's Avatar
Thanks, guys.
Power issues are all ok, right out to the injectors. I tested all the ecu power.
I also put power on one of the injectors and heard no click.
So the conclusion is coming down to stuck injectors. I am going to get the noid light and go from there. They have them at autozone. I could make one, but autozone is two miles away.
Shep
Shep
Old 07-31-2012, 04:00 PM   #6 (permalink)
sgspeed's Avatar
Got Injector Signal
I got the noid light and tested.. Injector signals are good. So its off with the KenneBelle Blower to deal with the injectors.
The universal failure is pretty interesting. They are stuck. This is also proven out by no clicking on power application.
Thanks a million.
I spent a long time checking circuitry. I never imagined that the injectors could be stuck. When I got the engine from the donor, the original injectors worked just fine and the car had been sitting for years. These are new 30 lb injectors with 10000 miles on them. That they would be like this was pretty far from my imagination. They were on the engine for 6 months off the engine for probably a year in a plastic bag, and then back on the engine, dry for about a year. Interesting.
Thanks again.
BTW. I had no idea what a noid light was until today. I had to google it. Just goes to show this is the only fuel injection engine I have ever worked on.
Shep
Shep
Old 07-31-2012, 11:21 PM   #7 (permalink)
Wade Chamberlain's Avatar
I had a set do that once! I was able to unstick them all.
I poked some holes in a cardboard box so I could prop them upright and squirted some penetrating oil in the top of them and let them sit for a few hours. With a couple of jumper wires and a 12V battery, I test fired each one. Some of them clicked right away. Others, I had to gently tap the pintle end on the bench a few times (on the plastic tip) to free them up, then they clicked too.
Wade Chamberlain
FFR2229K
Old 07-31-2012, 11:58 PM   #8 (permalink)
If you expect to get long lasting and consistant performance from those injectors, they need to be rebuilt. Clean them up, replace the seals and filters, etc. It's not very expensive, and even by mail order you can get them done in a few days.
I sent mine to Fuel Injection Connection. FUEL INJECTOR CONNECTION - Shop Home
I FedEx'ed them out on Tuesday, had them back by UPS on Friday. Cleaned, rebuilt, new filters and discs, new O-rings and seals, ready to install. Cost was about $160'ish, including overnight shipping costs.
Old 08-06-2012, 12:58 PM   #9 (permalink)
sgspeed's Avatar
Thanks To All
I decided I was not going to mess with the old injectors or rebuild them. Not knowing exactly what went on inside them was enough to send them to the dustbin for infiinite storage until later. I bought new injectors.
I bought new injectors from summit racing, put them in and the car fired up after about 1/3 of a revolution.
Thanks to all of you for the help, once again the forum rocks.
My car will be back on the road in two weeks.
Thanks Again.
Shep
Shep
