supercharged 347 belt problems - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Forced Induction / Nitrous
Old 08-27-2011, 02:32 AM   #1 (permalink)
41willys's Avatar
Finishing up building a 347 with a v-2 supercharger. Having problems with the serpentine belt for the accessories. Using a reverse water pump with a jones power steering pump and alternator with stock mustang idler pulley. Having trouble getting the belt to work. Any help would be appreciated, pictures, parts used ?
41willys is online now   Reply With Quote
Old 08-27-2011, 01:14 PM   #2 (permalink)
Rich A's Avatar
41Willys,
Pictures of what you have and how it is routed now would help.
Every Shelby built after May 10, 2012 are not original Shelby’s or Shelby continuations, but are Shelby replicas.
Sorry to burst your bubble.
"If someone doesn't comply with the federal registry of their gun, will it be illegal, or will Democrats insist on calling it 'undocumented'?" B.C. 1/23/13
Old 08-29-2011, 06:14 AM   #3 (permalink)
Id just pull up a picture of the belt routing on a stock 5.0. The easiest way to get the length is using a piece of string. Your supercharger belt should run off another pulley or a dual pulley in place of the factory crank pulley. You may have to try a couple diff. lengths in 1/2" increments to get the tension correct.
Should go over the alt, under the idler, over the PS, then the backside of the belt on the WP, down under the crank, back up to the alt.
jasonmark1993 is offline   Reply With Quote
