Turbo size and specs for single turbo set up? - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Forced Induction / Nitrous
Old 01-01-2011, 04:55 AM   #1 (permalink)
China's Avatar
I know someone will know this.
I'm looking to hit around 400-ish whp out of my 302 (explorer w/E303, 70mm MAF, 24# injectors)
Looking to do a single turbo. What size turbo (and spec) should I look for?
Thanks guys!
-China
Horse Power is an addiction!!
China is offline   Reply With Quote
Old 01-01-2011, 09:49 PM   #2 (permalink)
MJN
MJN's Avatar
First question what's your budget? Are you planning on a junkyard turbo set up or going all new? There are some great websites if you are doing it all yourself, if not talk to Wayne Presley about one of his kits. You won't be disappointed.
Mike....
MJN is offline   Reply With Quote
Old 01-04-2011, 03:35 AM   #3 (permalink)
carbon777's Avatar
Agree with MJN do some research first. Look up Corky Bell he has a few books available. Once you understand the basics and know what your looking to do with your car then you can select the right components to go with the turbo .... picking the turbo is only about 30%of what you need to know. True having someone give you a bolt-on kit is one route but usually the most expensive, least flexible but easiest.
Good luck.
"If everything seems like it's under control your just not going fast enough" (Mario Andretti)
carbon777 is offline   Reply With Quote
Old 01-22-2011, 05:58 AM   #4 (permalink)
Builder of OVERKILL!!
2fastCobra's Avatar
Talking
You can find out anything you need to know about turbo's from http://www.theturboforums.com/smf/index.php
FFR turbocharged 408W Dart Iron Eagle block 225 AFR race heads. Methanol injected, 83mm T6 turbo. Dyno numbers 924rwhp / 986rwtq *** dyno video*** http://youtu.be/u9CoxEh-eig
2fastCobra is offline   Reply With Quote
