Air to Air Install - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Forced Induction / Nitrous
Old 12-29-2010, 06:36 AM   #1 (permalink)
No Tread TommyG's Avatar
Air to Air Install
We (we meaning the other guy "Adam") just finished fabbing and installing the piping for the intercooler.
2 sizes smaller on the pulley, blower has a very different pitch now
Off to the dyno after breaking in the new tranny
Tom
No Tread TommyG is offline   Reply With Quote
Old 12-30-2010, 04:49 PM   #2 (permalink)
Tom Keiser's Avatar
Beautiful work, way to go!
FFR2636,Viper Red/ Arctic White. V1-SC Supercharged 308. T5Z, 3:73 3-Link rear, PS GT40 wheels, 5 lug w/4 wheel discs
Tom Keiser is offline   Reply With Quote
Old 01-22-2011, 06:18 AM   #3 (permalink)
Builder of OVERKILL!!
2fastCobra's Avatar
Talking
That looks like the same intercooler that I am using, the Treadstone intercoolers are made very well and they flow great. I have maxed mine out as far as heat exchanging efficiency but it does not limit flow so I am adding Water Methanol Injection to mine so I can push mine some more with out adding race gas to the mix. What kind of power are you looking to make?
FFR turbocharged 408W Dart Iron Eagle block 225 AFR race heads. Methanol injected, 83mm T6 turbo. Dyno numbers 924rwhp / 986rwtq *** dyno video*** http://youtu.be/u9CoxEh-eig
2fastCobra is offline   Reply With Quote
Old 01-22-2011, 07:09 AM   #4 (permalink)
builter's Avatar
Tom,
Can you tell me what Treadstone model you are using?
2002 FFR MK II, 302 FI Vortech Supercharger, Cobra intake, GT 40 heads, 36 lb injectors, FMU, 10 Lbs of boost, AIS water meth injection 3.55 gears, Soft top and still in gel coat.
builter is offline   Reply With Quote
Old 01-22-2011, 07:24 AM   #5 (permalink)
Hey 2fast, I thought that might have been the same one. I actually sent you a couple PM's awhile back asking about it.
Last dyno without the intercooler and tko500 was 585 whp. Adding more boost and the intercooler, but also swapping to a C4, who knows where we'll end up on the dyno : )
builtit, here's the link:
http://www.treadstoneperformance.com...es+Intercooler
FYI we ran into a tuning issue at cruising speed, getting some fluttering. We're adding a second bypass valve before the intercooler. The first one was after the intercooler close to the throttle body. Should be on tomorrow and back to they dyno next week.
Set up is a chipped A9L with a draw through meter.
Tom
Old 01-22-2011, 07:53 AM   #6 (permalink)
2fastCobra's Avatar
Talking
You wrote: ------------------------------------------------------------------------ Last dyno without the intercooler and tko500 was 585 whp. Adding more boost and the intercooler, but also swapping to a C4, who knows where we'll end up on the dyno : )
With that kind of power I think you are headed into the FUN ZONE. BOOST is the BEST!!!! Have fun.
Old 01-22-2011, 09:12 AM   #7 (permalink)
Ha ha, thanks 2fast. Still nowhere near your 1.21 gigawatt superfun zone!
Old 01-28-2011, 09:09 AM   #8 (permalink)
So the new dyno numbers with the C4 were interesting.
520 whp 477wtq
down from 585 and 540 with the stick
They tell me that's typical.
I guess the difference is, when I put my foot down, instead of climbing through the rpm range gradually increasing power, it just went straight to 5000 rpms (3rd) making near peak right away. Stabbed it once on the freeway in 3rd and spun the M/T drag radials.
Heading to the strip on Feb 5th, we'll see how it does.
It'll be my first time with a racing auto trans and a good converter.
Tom
Old 02-01-2011, 12:03 AM   #9 (permalink)
2fastCobra's Avatar
Talking
How much boost are you making now? You will loose about a pound or two pounds boost with the intercooler. Also if you went down two pulley sizes you may be getting some belt slip. What trim Supercharger are you running? My S-trim had pulley slip very bad as I went to the smaller pulley sizes. The only pulley that worked for my S-trim was the Ultra Grip Pulley from Reichard Racing, when I upgraded to the T-trim and the JT-trim the slip was better because I did not have to push the blower as hard. I recommend the Ultra Grip Pulley because the grooves give the belt something to pull agaist and they just look cool. I may be going to a PowerGlid auto soon, it will help load my turbo better and no more on and off the gas shifting. Good luck.
Old 02-01-2011, 05:04 AM   #10 (permalink)
Hey 2fast,
I'm running the S-trim. The boost stayed exactly the same at 14. Good to hear your experiences with the different trims. I was thinking about stepping up to a T-trim if I didn't go to a turbo.
I bet a powerglide would be the perfect tranny for your car.
Keep us posted : )
Tom
Old 02-17-2011, 01:54 AM   #11 (permalink)
2fastCobra's Avatar
Talking
I finally got around to taking a few pictures of my intercooler mounted in the nose of my car. The bottom two pictures show the way I ran some of my intercooler piping. It is easy to see how my turbo got a rock into it the day I ran with-out a filter. --------------------------
Old 02-17-2011, 05:19 AM   #12 (permalink)
Yours looks great.
I'm trying to figure out how you got an un-even tank to look even : )
Made it to the track, 10.12 @132 vs 10.56 @ 130 with the stick.
65 less whp on the dyno, 4.5 tenths faster in the 1/4 mile. I love saying that. Same set of tires too.
Almost 2 whole tenths in the first 60 feet.
Vids in the drag race section.
Old 02-17-2011, 11:22 AM   #13 (permalink)
MJN
MJN's Avatar
Looks like careful use of flat black paint. Nice job.
Mike....
MJN is offline   Reply With Quote
Old 02-21-2011, 04:40 AM   #14 (permalink)
2fastCobra's Avatar
Talking
The paint is special heat conductive radiator paint that I got from Eastwood, it is a semi-gloss black and very thin so it takes a few coats to get good coverage. I think it came out nice and goes good with my paint scheme.
