My turbo FFR on E-85. - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 24 (permalink) Old 05-06-2007, 10:02 PM Thread Starter
I thought that I should also post a link to my FFR here which has a S400/S80 turbo running Accel DFI and E-85 gas. Which made 817hp and 793 torque on 16 lbs boost and very safe tune done by Andy at Dynotune USA.
http://dynotuneusa.com/factoryfive
Dart 428w built by R&S racing, S400/S80 turbo, Accel DFI, Tuning by Andy at Dynotune USA, E-85, 4R70w manual shift trans, IRS, looking for 1000+ rwhp and low 9's.
79pacecar is offline
post #2 of 24 (permalink) Old 05-07-2007, 02:07 AM
mk 1.5 original
WOW!
Those are some incredible numbers. I bet that thing is just plain scary when you stand on it.
Chris
FFR3117,SN95 donor and computer,vortech SI trim @12#'s,Tweecer rt,cobra brakes,dual rollbars,3:73's,SRP paint, cobra R's, BF Goodrich KDWs 12.39@118mph 1 mile+ ASL
motorheadcrm is offline
post #3 of 24 (permalink) Old 05-20-2007, 03:00 AM
Oh my God!!!
That is one incredible beast!!!
Great job!
juno03 is offline
post #4 of 24 (permalink) Old 07-03-2007, 07:04 AM
GTM wanna be
PREDATOR's Avatar
Damn! That's some crazy numbers, and you still get a decent price on gas...
PREDATOR is offline
post #5 of 24 (permalink) Old 07-03-2007, 12:48 PM
MJN
MJN's Avatar
I can't wait until E85 makes it to the North East. Until then Cam 2 is the only option.
Mike....
MJN is online now
post #6 of 24 (permalink) Old 07-04-2007, 09:30 AM
Awesome numbers!
Can't wait for E85 in California either [img]smile.gif[/img]
Tom
tommyg is offline
post #7 of 24 (permalink) Old 10-22-2007, 04:59 PM
Send a message via AIM to mystang
79pacecar. Do you have any more detailed pics of the turbo setup? Are you using log style header,shorty, custom?
2002 DIY turbo v6 mustang
338 rwhp 380 rwtq @ 10psi
mystang is offline
post #8 of 24 (permalink) Old 10-22-2007, 05:29 PM
At nearly 800ftlbs of torque how do you think the 600ftlb "rated" TKO600 will hold up?
Have you had any problems already?
Benji is offline
post #9 of 24 (permalink) Old 10-30-2007, 05:54 PM Thread Starter
Mystang, I'm using trickflow highport heads and using headers built by trickflow for these heads, these are a midlength header and then going into 2 1/2" exhaust tubing into a merge with newgen wastegate. For a turbo I'm using a S400/S80 turbo. For exhaust I'm using 5" and a mangnaflow bullet muffler.
Benji, My trans was built by promotion using TKO500 internals and then all clerances checked and adjusted to there specs alone with several other mods that they do. I'm using a twin disc clutch. This setup help up fine put it's not the best for a car with this much hp, so I had a 4R70W built using a lentech manual valve body and going to be using triple disc lockup torque converter.
Later..
post #10 of 24 (permalink) Old 11-01-2007, 02:19 AM
Thomas W's Avatar
79pacecar, are you still running the same block? I don't blame you for switching to an auto, my lentech aod is going in next week.
Thomas
FFR 4031K, twin-turbo dart block 331, AOD, 144.91 mph in the 1/4 mile
Thomas W is offline
post #11 of 24 (permalink) Old 11-02-2007, 01:38 AM Thread Starter
I'm having a dart iron eagle block built using billet calis crank and billet oliver rods, along with all of the good parts. My goal is to increase boost and have 1000+ rwhp.
post #12 of 24 (permalink) Old 07-25-2008, 03:22 PM
Thomas W's Avatar
Any update on this car?
Thomas
Thomas W is offline
post #13 of 24 (permalink) Old 07-26-2008, 07:24 AM
BLISTIC's Avatar
Yeah it was last seen orbiting the Moon! I have ridden in a 500 RWHP SP Cobra...One scary ride. When standing on it in 2nd and 3rd all I could do to keep it straight.
This E85 conversion is really starting to make sense.
My f-150 is e85 (flexfuel) compatible. Hmm if there were only more E85 stations in SOCAL.
Build it...
BLISTIC is offline
post #14 of 24 (permalink) Old 07-26-2008, 01:42 PM
Don DePontee's Avatar
Send a message via AIM to Don DePontee
Why would anyone want to run the lower powered E85 which drops your performance and mileage by almost 25% (why did you think the price was so cheep to begin with) Am I missing some thing here and can you imagine what the numbers would have been on high octane gas.
Don
FFR-4000, CHP 408ci./600hp, Wayne's Stack F.I. & Tec-3, T-600, IRS, Smith gauges, 17" Pin-Drive wheels, Whitby's rag top & paint by Ken Pike (SRP).
Don DePontee is offline
post #15 of 24 (permalink) Old 07-26-2008, 01:49 PM
MJN
MJN's Avatar
Don.
The octane rating of E85 is significantly higher than pump gas so for a forced induction application you can run a lot more boost and / or timing the result being stupid amounts of HP.
I agree than for normally aspirated motors it really doesn't make much sense but for blown cars it does.
Mike....
MJN is online now
post #16 of 24 (permalink) Old 07-26-2008, 02:40 PM
Now that makes sense, I sure hope that the E-85 prices don't creep up as people get comfortable using it.
Don
post #17 of 24 (permalink) Old 07-26-2008, 02:48 PM
Thomas W's Avatar
Don, I think the octane rating of E-85 is in the 105 range. Quite a bit cheaper than unleaded race gas.
Thomas
Thomas W is offline
post #18 of 24 (permalink) Old 07-28-2008, 02:16 AM Thread Starter
I finally got it running about 3 weeks ago. It is alot fast then before and easier to drive with the 4R70W transmission. I was going to dyno it on saturday at car craft summer nations but it was booked all day on saturday and I need to do more tunig before I turn the boost up and try for 1000 hp dyno run. I'm also going to go drag race it, with in the next month hopefully. I'll post some pics in a few days. Also the reason the you run E85 gas is because you can make alot more hp on it compared with other pump gas. There was a camaro at car craft that dyno 1300+ hp.
post #19 of 24 (permalink) Old 07-28-2008, 02:37 AM
Thomas W's Avatar
79pacecar, glad to hear you have it up and running. Are you going to have a cage? If not, I'll be surprised if they let you have more than one pass at the track. At least that was my experience. Please have someone video you, a lot of us will be looking forward to seeing it run. It's great to hear about another turbo ffr. I answer a lot of pm's about people planning on building a turbo car, but almost none end up following thru with it. Keep us updated. Cheers.
Thomas
Thomas W is offline
post #20 of 24 (permalink) Old 07-29-2008, 05:54 PM
79pacecar
I saw your car at CC last weekend, you were parked next to the fence bordering Snelling, correct?
Nice car, and that turbo is massive.
There were a few high power cars there on the dyno, too bad you couldnt get on.
Current car(donor?) 85 Mustang GT w/5.0 Novi Blower and more 12.4@117
Odrapnew is offline
post #21 of 24 (permalink) Old 07-29-2008, 07:13 PM
DalMor's Avatar
Get the corn out of the Tank & back on the Table ! - hehe.
Remember the " Law of unintended consequences " -
http://www.usatoday.com/weather/clim...ol-study_N.htm
I'm no greenie - nor a global alarmist- but food ( especially feed for cattle ) has skyroketed by 600% - simple choice - food or gas ? - ( or beer/ bourbon , etc )
Of all places - heres an article from SF Cali - http://www.sfgate.com/cgi-bin/articl...w145539S09.DTL
79pacecar - I think its awesome that you guys can get those numbers ! - I still think the future autos will be on the turbo 3/4 cyl platform, very efficient - low weight, powerful, good mpg, maybe you need to show the BIG 3 how its done !
5.0L Trick Flow heads & cam, Edelbrock RPM Air gap, Quick Fuel Carb, MSD, Levy Super Alloy T-5 & 3.55 rear AC Team III Hailibrands
Lexus Platinum Metallic - Audi Black Magic Pearl stripes.
DalMor is online now
post #22 of 24 (permalink) Old 07-30-2008, 01:27 AM Thread Starter
Thomas, I had a cage built last winter that bolts in, it uses a standard ffr driverside rollbar and I had a halo with down bars welded on it along with a bar going from the ffr rollbar to the passenger side downbar and have a swing out bar on the driverside. I also had additional bars welded into the halo and also supporting the halo. I'll post a picture the next time I have it mounted in.
post #23 of 24 (permalink) Old 07-30-2008, 03:00 AM
Thomas W's Avatar
79pacecar, could you possibly send me a pic of that in and out of the car. I would absolutely love to have something like that made up for my car. Thanks in advance.
Thomas
Thomas W is offline
post #24 of 24 (permalink) Old 08-01-2008, 10:12 PM
Qwik 1's Avatar
Pacecar,
I also would like to see how you did the downbar. I have the same cage setup minus the downbar. Would love to see the swingout. Did you have to sculpt the door?
A government big enough to give you everything you want, is strong enough to take everything you have. Thomas Jefferson
Best ET 10.44 @127 mph
Qwik 1 is offline
