Inner Tie Rod, how do I remove it??? - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Brake and Suspension Tech
Old 08-15-2011, 10:52 PM   #1 (permalink)
THEDON's Avatar
History;
2009 full 65 coupe kit, but using a AutoZone 1993 PS rack
94-95 straight arm spindles, and FFR tie rod ends
I am trying to remove the inner tie rods form the rack to install the extensions.
I have put about 50lbs of pressure on the inner tie rod nut in the regular loosening direction, but before I get out the BFH I though I would post here.
I don't see a pin in that hole holding anything but I've been wrong before
The awesome manual says "Pull back the boot and remove the inner tie rod from the steering rack"
Here's what I'm looking at;
[/URL]
Also I plan on using urethane offset bushings just cause i have a set from a mustang build, and I assume that you would use them to lower the rack, hopefully putting it better parallel alignment w the LCA's?
Thanks in advance for any info.
Miami, FL
65 Coupe #439, Complete Kit, 3 Link, Terminator Cobra Motor, TKO 900
THEDON is offline   Reply With Quote
Old 08-17-2011, 01:28 AM   #2 (permalink)
THEDON's Avatar
There must be dozens of ppl that have removed these. Anyone have ANY ideas, i would love to knock this out.
Miami, FL
Old 08-17-2011, 01:51 AM   #3 (permalink)
tweeker's Avatar
I put the rack in the vise and used a BF wrench. I seem to recall a rivit in the hole that made running the end off a bit difficult. Probably abit more than 50 pounds needed.
tweeker is offline   Reply With Quote
Old 08-17-2011, 02:05 AM   #4 (permalink)
Sanford's Avatar
I believe there is a roll pin that has to be removed.
Rack extenders, How do you install?
Old 08-18-2011, 04:08 AM   #5 (permalink)
THEDON's Avatar
Thanks for the reply's, guys. I put the rack in the vice and using a BFH and a BF wrench was able to get the inner tie rods unscrewed. The Autozone rebuild didn't have any pins, but the holes were there so I imagine the factory untouched ones do.
I used copious amounts of loctite red on all the joining threads, installed the extenders , and set it to dead center. I got a 3 turn lock to lock.
Now we will see if I need to cut the tie rods at all. Sounds like I will but we will see.
Miami, FL
Old 08-18-2011, 12:06 PM   #6 (permalink)
Mike,
I don't know your exact set up but you probably do not want to put the lowering bushings in the rack. Having the steering arms parallel to the lower arms would only be optimal if they are the same height off the ground.
Jim Schenck
Factory Five Racing R&D
Jim@FactoryFive is offline   Reply With Quote
Old 08-18-2011, 07:52 PM   #7 (permalink)
THEDON's Avatar
Jim, thanks for letting me know! I will use the stock ones then.
Miami, FL
Old 08-18-2011, 08:43 PM   #8 (permalink)
We know what you're up to
Don Payne's Avatar
Seems like most of us trimmed the inner tie rods a little just enough to get the outer tie rods to be at 1/16" total toe-in. Mine, prior to trimming, could not even get in the ballpark of 1/16" toe-in on initial mock up.
-Don
