Electrical Gremlins - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Audio / Electronics
Old 10-05-2010, 06:11 PM   #1 (permalink)
Electrical Gremlins
Something funny has happened with the head lights and I don't know where to start looking.
I went out Fri. night to a local car show with the cobra and being dusk I had my head lights on, no problem. When I left to go home I noticed the left head light was out, so I thought.
Now that it's home in the garage I went to check out a few things. When I turn on the head lights the left one is not totally out but is extremely faint, just a slight glow. Then when I turn on the high beam the left one works just fine but the right one goes out. I have checked for loose connections and found no obvious ones. I fiqure the fuse is fine or I would have no lights at all.
The question is where do I check next, relays, grounds or any other suggestions?
Thanks in advance.
Hawkeye is offline   Reply With Quote
Old 10-06-2010, 05:32 PM   #2 (permalink)
1FAST05's Avatar
I would start with the grounds.
1FAST05 is offline   Reply With Quote
Old 10-06-2010, 06:29 PM   #3 (permalink)
Mark_VA's Avatar
Ditto. Make sure the frame is sanded to the bare metal at the ground points.
FFR #6492 - Delivered 02/18/2008
Engine In - 06/03/2008
First start- 08/15/2008
First failure- 08/18/2008
Engine #2 in- 11/08/2008
First Start #2- 11/20/2008
Titled and Registered- 10/12/2010
331 EFI, T5, 4-wheel disk brakes, Ford X303 heads, Ford E-cam, 1.6 roller rockers, Edelbrock Performer intake, 65mm TB, stock MAF, 19lb injectors, 3.55 rear end.
Mark_VA is offline   Reply With Quote
