Speaker question - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Audio / Electronics
Old 07-30-2010, 02:21 PM   #1 (permalink)
Speaker question
Bare with me as I am audio ignorant....I am installing stereo equipment in my roadster that I had sitting around from other project cars. I am using a JVC CD player, 2 6X9 JBL 250W rms speakers and a jensen 100X2 peak amp. When I turn the radio up, the higher sounds are super loud and super clear but there seems to be no low range sound and any bass or beats in a song distorts the speakers badly. Obviously my components are mismatched? What do I need to do to get better low sound along with the crisp clear highs that I am already getting from my speakers? Do I need a different amp?
dbird is offline   Reply With Quote
Old 07-30-2010, 07:17 PM   #2 (permalink)
Many things can create this situation but to at least get you going:
Check the polarity (+ and -) on all your wiring from the head unit all the way back to the speakers.
On your head unit, what kind of equalization capability do you have -- where is it set?
Maybe you only have simple bass/treble control, what happens when you adjust?
You mention your speakers are 250w RMS -- at what ohm (resistance) rating?
You mention your amp is 100x2 peak -- what is its RMS rating and at what ohms?
(As you have already touched on, gross mismatch between what the speakers need/are pulling versus what the amp can deliver and at what resistance is a good possibility based on your description...example, your speakers are rated at 2 ohms and your amp isn't even rated to go down to 2 ohms but needs a load of 4 ohms or more...)
Are the power and ground wires to your amp adequate for the needed current. (Did you use the gauge wire recommended?)
How are your speakers mounted -- or are they yet?
Do you know for sure each component is working properly -- how do you know?
Lots of other things regarding low/high pass filters, crossovers, gain controls etc. but perhaps check the basics out first....
HTH,
MKII, PDW, Torsen 3.55 Pin Drive IRS, Dart 393W, AFR 185's, Victor Jr., Accufab TB, Accel DFI GEN 7 EMS, TKO 600 wMcleod Scatter&Street Twin Clutch, 1+1 Elec., TTD's, Da Bat Paint
Bill Lohmiller is offline   Reply With Quote
