Question for you IPOD to AMP set-up users - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Audio / Electronics
Old 05-02-2010, 03:59 AM   #1 (permalink)
YallsChris's Avatar
Guys, see following thread after having read below::
http://www.ffcars.com/forums/showthr...=1#post2232019
I have some issues and was wondering what AMPs you are using with your IPod Y-Cable set up and if you have experienced similar issues.
Thanks, Chris
You miss 100% of the shots you never take.
Roadster 6688 delivered on 07/05/08, 1989 LX 5.0 donor, SN95 front brakes and rear axle, Roller and Engine in on 12/30/2008. First Start on 04/25/2009 and a success. Paint by Whitby: Molton Orange Candy over Coarse Silver with Stripes. Graduated on 07/15/2009 with maiden ride following on 07/16/2009. All well. Progress Blog @ www.christopherludwig.de
YallsChris is offline   Reply With Quote
Old 05-02-2010, 02:40 PM   #2 (permalink)
YallsChris's Avatar
Anyone
I am sure there are plenty of guys here that have the similar set up and can comment?
Thanks, Chris
Old 05-02-2010, 04:12 PM   #3 (permalink)
CobraRad's Avatar
I recently installed an IPOD/AMP setup in my MKII roadster. But I can only provide limited insight, as my car isn't on the road yet...
I went with an Alpine pdx-5 amp (4x75w, 1x300w). I am using polk audio component speakers (5.25" front and 6.5" rears). I also installed a subwoofer in the trunk (JL Audio 10" low profile box). I purchased a custom (length) y-cable from bluejeanscables.com.
I still have to make some adjustments, but I am so far very happy with the way it sounds.
"A government big enough to give you everything you want, is strong enough to take everything you have." - Thomas Jefferson
CobraRad is offline   Reply With Quote
Old 05-02-2010, 05:52 PM   #4 (permalink)
YallsChris's Avatar
Sound is great
CobraRad, thanks for the detail on what model AMP you are using.
I agree on the sound. I always had very good sound, just now it seems something is not working anymore as the AMP changes to PROTECT mode and shuts down sound. I think it happens when I increase the volume to 3/4 or more on the IPod. Never happened the past 6 months and just started. Y-Cable is ok as I tested another one and saw the same issue.
All others, what AMP are you using and has anyone seen similar issues after use?
Thanks, Chris
Old 05-02-2010, 06:26 PM   #5 (permalink)
nickm1024's Avatar
I used to really be into stereo's but have limited knowledge now so my advice is worth every penny it costs you I have my ipod setup directly to amp. Amp is a pioneer 175x2 RMS. FYI I wouldnt go out any buy a pioneer but I won a sales contest and they only carried pioneer. May sound like overkill in terms of power but here is my logic. When using an Ipod/Mp3 device connected to a head unit you set the volume on the ipod at 50% volume and then adjust volume with head unit. THis is to prevent the "spike" that is mentioned in other thread. Well, since we arent using a head unit not much option here. SO I got an amp that delievers more power than I need and I turned the output down way low. THought going this route may make it less sensitive. So far so good. I would try a more powerful amp and turn the output down.
Delivered 3/26/08.
Rollin on temp tags and drivin in gelcoat 10/16/08
Painted and on the road 4/4/09
FFR 7501
Dec '12 repowered 408w w/ mass Flo
nickm1024 is offline   Reply With Quote
Old 05-02-2010, 11:46 PM   #6 (permalink)
Hot Rod Fanatic
Runninman92's Avatar
It is most likely the input voltage from the ipod. Your Amp might not have a high enough input sensitivity being as old as it is. Most new amps are able to receive an input voltage as high as 8 volts. But some older amps could not take more than 2 volts. It would work for a while and then burn up the amp as it was being overdriven. You can check the voltage from the ipod at 3/4+ volume. If it is above 2 volts (and I believe it is.) you have your problem figured out.
Above all things do unto others as you would like done unto you.
Runninman92 is offline   Reply With Quote
Old 05-03-2010, 01:25 AM   #7 (permalink)
YallsChris's Avatar
Super
Great input guys.
I was wondering if the AMP is too sensitive to the input.
Guess I might be checking for one online with special attention to the input sensitivity.
Thanks, Chris
