Tire Repair Question - FFCars.com : Factory Five Racing Discussion Forum
Tire & Wheel Forum sponsored by The Tire Rack  ·  Call: (877) 522-8473  ·  TireRack.com
Go Back   FFCars.com : Factory Five Racing Discussion Forum > General Topics > Tire & Wheel Forum Sponsored by The Tire Rack
Old 05-03-2012, 12:10 PM   #1 (permalink)
AyRoMoDa's Avatar
Question Tire Repair Question
I think I know the answer to my question, but I'll ask it anyway.
I bought a set of Nitto NT-05 (255-40-17 front, 275-40-17 rear). I have about 300 miles on them so far (including track time at Watkins Glen). So far I'm happy with the grip, but I'm not so sure about tread life, but that remains to be seen. I plan to be primarily street the car with very occasional track use.
As I got home last night, the roadster didn't look right and I found that I have a screw through the rear passenger side tread.
My question is: should I have the tire repaired or should I replace it?
Thanks in advance for the advice.
Paul
FFR 6911, 306 EFI, 3-Link, T-5, 3.55
Still in gel coat but legal 4/9/12, 3,700 miles and counting.......
AyRoMoDa is offline   Reply With Quote
Old 05-03-2012, 02:06 PM   #2 (permalink)
DealsGapCobra's Avatar
Exactly what do you mean by side tread? The obvious and safest answer is to replace but I am not 100% sure that is what I would do. Can you post a photo?
Rob
12/7/1941
9/11/2001
3/21/2010
DealsGapCobra is offline   Reply With Quote
Old 05-03-2012, 04:20 PM   #3 (permalink)
FFR5452's Avatar
Sidewall, replace.
Tread, plug or patch.
FFR5452 is offline   Reply With Quote
Old 05-03-2012, 04:23 PM   #4 (permalink)
AyRoMoDa's Avatar
I meant to say rear passenger side tire. The screw is in the tread, not the side-wall. Attached is a pic of the screw.
I was wondering if this could be repaired (i.e., plugged) or should I suck it up and just replace the tire.
Thanks again,
Paul
Old 05-03-2012, 07:06 PM   #5 (permalink)
MJN
MJN's Avatar
Plug it. I bought one of these kits a few years back and have saved way more than it cost me on tire repair. I keep it and a 12v compressor in the trunk of the FFR. Used it once on my FFR, once on the wife's car, twice on the lawn tractor and have helped out a couple of other people. Pocket Tire Plugger - For All Tubeless Tires - Stop & Go International Inc Store
Mike....
MJN is offline   Reply With Quote
Old 05-03-2012, 07:25 PM   #6 (permalink)
plug it. I'm like MJN carrt that plug kit and 12v compressor in the trunk of the roadster all the time.
FFR#6983 ordered 4-15-09 delivered 05-21-09, 96 explorer 302 mustang 5spd, 94 must gt 3:27L rearend
freddiehebert is online now   Reply With Quote
Old 05-03-2012, 07:55 PM   #7 (permalink)
lewpoberezny's Avatar
I do 10-20 tire repairs a day. The safest is to have it taken off the rim and patched. If the hole is 1/4 in have them use a plug patch. A plug usually will leak over time again but a patch will last the life of the tire. I do believe in keeping a plug kit in the car but for emergency and temporary repair only. I see no need to replace the tire unless when it comes off the rim and rubber dust is found, this is from driving on a low tire. It does not take to long for this damage to start. It sounds as though you caught this early.
Have a safe day,
Lew Poberezny
Wauwatosa, WI 53222
MKIV ordered Sept. 02nd 2010
Stewert Delivered Oct. 11th 2010
Order Forte's Magic Dec. 02nd 2010
Roller Dec. 04th 2010
Graduation Video June 22nd 2011
http://www.youtube.com/watch?v=mCWmte6BX9Q
Vredestin 245/45R17 Front 315/35R17 Rear
See build details at my Blog
http://ffr7347build.blogspot.com/
lewpoberezny is offline   Reply With Quote
Old 05-03-2012, 08:58 PM   #8 (permalink)
AyRoMoDa's Avatar
Thanks guys.
I think I'll have it patched for now but will definitely get a plug kit and 12V compressor for road emergencies.
Thanks again,
Paul
Old 05-03-2012, 09:07 PM   #9 (permalink)
Originally Posted by AyRoMoDa View Post
Thanks guys.
Thanks again,
Paul
Great. I have used plugs when needed but a patch is the "right" fix. Patch it and forget it.
Rob
12/7/1941
9/11/2001
3/21/2010
Old 05-08-2012, 02:14 PM   #10 (permalink)
agreed ... good post !!!
Luke@tirerack is offline   Reply With Quote
Old 05-08-2012, 04:33 PM   #11 (permalink)
AyRoMoDa's Avatar
Update:I had the tire patched, no internal tire dust. I put it through its paces over the weekend and it held pressure, no problem. Good as new.Thanks to all for the advice!Paul
Old 07-18-2012, 08:18 AM   #12 (permalink)
See tires will contribute to get better mileage, typically you can replace your tires after 25000 to 30000 miles, but if you feel that that are not working properly then replace the same
Angel smith is offline   Reply With Quote
