Putting An LS Motor Into An FFR Roadster (Long Read) - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Factory Five Racing Roadsters > Chevy (or any other non-Ford) Motor Builds
Old 09-12-2011, 03:19 PM   #31 (permalink)
5 link and t-56
I am doing the homework on setups for the roadster and beleive i want to go with the LSx series motor. Couple questions
anyone running a TKO 600 with the LSx motors? if so what was required to make it work?
it seems if you run the t-56 you must run the IRS as well. I am wanting to run a solid axle with 3 or 5 link. I saw one guy running a solid with t-56 on here not sure what was involved in making it work though.
Jason
mobius is offline   Reply With Quote
Old 10-23-2011, 02:39 AM   #32 (permalink)
duramaxhd's Avatar
Mobius: The major hurdle for any engine is drive shaft length. If you are going to run an Aluminim LSx then it would be no biggie to push the motor a few inches forward and still maintian a 50/50 balance. An Alum. LSx is far lighter than anything Ford makes. Most run the IRS because drive shaft articulation is not a problem and the car will handle/ride better.
duramaxhd is offline   Reply With Quote
Old 10-23-2011, 06:41 AM   #33 (permalink)
Tails's Avatar
The first thing that comes to mind is you will need to use a different bellhousing for TKO600 trans. I believe you can hitup Mike Forte, a vendor here, and see if he has something for you.
As far as the running a T56 with a live axle. 4th paragraph of the first post.. Myself and another are running that setup. However, like it's been said, if you want ride quality go the IRS route..
Tails
Daniel
FFR MKIII Roadster Complete Kit, 3-Link, GM LSx Block, T56.
Build Pictures
Build Blog
First Start
GoKart
Lets Take A Ride
Tails is offline   Reply With Quote
Old 11-12-2011, 04:27 PM   #34 (permalink)
I'm running a tko600 with my ls3/480. I got a bellhousing and hydraulic throwout bearing from kiesler engineering. The bell is nice, I will recommend their products, but not their service. They sent the wrong hardware with my bellhousing and stripped out the threads in my new engine...I was not happy. But with the proper hardware, everything fits and is sitting in my MkIII chassis now with very little modification.
ffr598 is offline   Reply With Quote
Old 12-17-2011, 07:03 PM   #35 (permalink)
Trans, clutch, Hyd release bearing, etc vendor
Try the guys at American Power Train, also known as the Driven Man
jim copland is offline   Reply With Quote
Old 01-13-2012, 05:58 PM   #36 (permalink)
Cool thanks!
I would go IRS except I want a lot of power! I have an 03 Cobra currently with the IRS and about 700hp but, i am thinking I am going to be in the 1100hp + range and doubt the IRS will handle it. Although I will mostly be rolling the power on and not doing drag race style launches so it may...
Old 01-18-2012, 04:06 PM   #37 (permalink)
Awesome build man.
uncle_darnell is offline   Reply With Quote
Old 11-24-2012, 12:09 AM   #38 (permalink)
Looking forward to talkin with you...Doin an ls1/th350 roadster build here in Texas
xssive is offline   Reply With Quote
Old 03-30-2013, 02:48 AM   #39 (permalink)
Did Mobius build the 1,100HP monster?
lap_dog is offline   Reply With Quote
