Honda Civic ball joint help - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Off Topic > Other Cars
Old 08-13-2012, 11:17 PM   #1 (permalink)
Cobradavid's Avatar
I'm helping out a friend with his 2002 Civic. He needs the control arms and struts replaced. He has the parts but we can't seem to get the ball joint separated from the lower control arm. The ball joint is still good, so I don't want to use a pickle fork on it and mess it up. I checked all the local auto parts stores and they don't have a ball joint separator tool for rent/borrow. I've seen some of the tools for sale on-line, but I'd rather not spend $70-100 on a tool I'll use for 5 minutes total.
Any tricks to getting the ball joint to separate from the control arm?
David
My Saving Grace: John 3:16
My car: http://mysite.verizon.net/resshc7d/
FFR6687, Graduate #39 in the Class of 2009
March 2012 POM on The Other Forum
Cobradavid is offline   Reply With Quote
Old 08-13-2012, 11:33 PM   #2 (permalink)
usually a very large hammer to the side of the knuckle will free it. Just keep hitting it right where the ball joint passes through.
Old 08-18-2012, 01:49 PM   #3 (permalink)
I hate to say this but some times they just do not come a part. Do what Mike said but I have seen the ball joint come loose from doing it you can replace the the bushings in that control arm and the struts go bad all the time be carreful not to pull axle out of the inner joint
Gregg Wade is offline   Reply With Quote
Old 08-19-2012, 12:30 AM   #4 (permalink)
streetbeast's Avatar
No Do Not Hit the control ARM.You want to Hit the Knuckle.Remove the ball joint nut.I also remove the tie rod from the knuckle too.Turn the hub assy and then hit where the ball joint goes into the knuckle.2to 4 hits should do it.Or if you have a pry bar that will fit between the arm and the knuckle you can pop it lose that wat too.
streetbeast is offline   Reply With Quote
Old 08-19-2012, 03:28 AM   #5 (permalink)
HIT THE ARM!!! the balljoint is pressed into the knuckle and the tapper is in the control arm. I have been a Honda tech for 28 years DO NOT HIT THE KNUCKLE it could cause the joint to become loose and pop out while driving pushing it into the outer C/V joint. I have seen it happen nothing good can come from hitting the knuckle.
Gregg
Old 08-19-2012, 09:20 PM   #6 (permalink)
Cobradavid's Avatar
Thanks for the suggestions
On one side, I could separate the ball joint stud from the control arm using a large tie-rod/pitman arm separator tool. Popped right out with no problems. The other side was more difficult, but I eventually got it separated.
David
