Hello all. I need some thoughts on the engine in my Mercury. As I had posted earlier this year, after 7 years being parked in the garage, I had gotten my Mercury back on the road this summer. I drove it for a couple months and found a lot of bugs, some due to sitting, some due to age and some due to some mistakes made along the way.
Here are the basics. Its a 1978 Marquis with the 351M engine and FMX tranny. Underpowered with a weak transmission. I have updated to dual exhaust, Mallory Unilite distributor, an Edelbrock Performer intake and a Holley emissions legal 4bbl. Everythng else is stock.
The bad-most of the emission parts are either not working or missing. I cap off the vacuum whenever I find a leak, but I'm thinking I wouldn't be upset to see it all go. There is a vacuum leak in the intake and the carb needs a rebuild. I didn't realize how rich it was running until I overheated one of the convertors and plugged it. Slight valve cover leaks, but not burning any oil or antifreeze. I suspect that having sat for so many years, the valve train is a mess and if I'm going to get that far into it, I might as well pull it and have the bottom end looked at as well.
So with all that, I am trying to decide the best route to go. I am not married to the idea of keeping this engine and tranny. What I would like to achieve is:
1. Improvement over the 150 hp the car had new.
2. Reasonable mileage (It used to get 21 on the highway and mid teens in town.
3. Reliability. I will give up power to be able to drive across country if I wanted to.
4. As low a budget as realistically possible.
5. While not too concerned about emissions, I would like to keep the cats and tune reasonably to be somewhat eco-conscious, unless the results would be minor.
6. I'm not looking to make this car fast. I would like to be able to get out into traffic without worry, but behave more like a cruiser.
So with all that in mind, do I keep the engine and tranny and rebuild? Are the parts I put on it worth keeping or are there better choices? Drop in a Windsor or a 460? Go nuts and drop a diesel in it? Regardless of engine, what would be a good trans choice? How much work to maybe upgrade to an overdrive trans?
And spend a bit on a good tune up. Other than maybe some performance updates like intake and exhaust. ditch all the smog crap and it wil not only run better, but more than likely cleaner.
I've decided that I will be staying with the m engine that's in the car now. The trans will bolt up and the intake, etc that I already have will save me some money and conversion issues that I don't know if I could handle.
Here are my questions. The price I got for a carb rebuild was around $250 which isn't much less than what I paid for it. Does this sound right? For the money, I'd rather go with something different since the need for emissions is no longer required.
I think due to the amount of work that would need to be done to rebuild the engine, and since I am staying primarily stock, I am going to go with a long block replacement, possibly upping to the 400 since everything I already have will work. Of the national suppliers, does anyone have good, bad or indifferent experience with any of them? Does anyone in the Minneapolis area know of a good local company? Am I wrong in thinking it would be more expensive to rebuild my current engine than buy a reman?
Following up to the above. I'll be pulling the car out of the garage hopefully early next week. Due to ability, money, time and tools, I am limiting myself to the following.
1. The intake has a vacuum leak, so I'll pull that, clean it up and replace. Both valve covers as well
2. the remaining not functioning emissions valves will be coming off.
3. the quote I got to rebuild the carb starts at $250, so I'll probably just buy a new one for the money.
4. All of the "Tune up" parts were replaced last summer, so nothing new there.
5. The big one, and what I need some recommendations of other Minnesotans, is the exhaust. I parked it last year because it started giving me fits on the way home from work. I limped it to a parking lot and found both converters glowing red. I knew it was running rich, but pushed it anyway. It wouldn't run over an idle, so I had it towed home and parked it. I am going to assume that both have plugged themselves solid. That said, I need to get the converters replaced or eliminated, neither of which I can do. Any suggestions for shops in the area?
I have the front bumper and front body components, but still need a ds fender before the body work can be done. I will drive a little longer with the body damage, I just want it to run.
