'94 302 Pulley Questions - FFCars.com : Factory Five Racing Discussion Forum
Old 08-25-2012, 12:41 AM   #1 (permalink)
I bought a 1994 Cobra engine, it didn't come with any of the front accessories so I'm slowly building it out.
Looking for a good flashy pulley set, and came across this set from March. However, poking around I'm finding there are a number of front timing cover differences between the 94-95 302 and prior years.
I'm wondering if anyone knows which pulley sets/support brackets work on the 94-95 timing covers? Anyone have experience with the March 30120?
Any other suggestions? I'm running no AC or PS.
PS. I'm going off the assumption the 94 5.0 Cobra has a reverse rotation water pump. If this is incorrect, please correct me
Thanks for the help and advice!
mm
Matchinthebox is offline   Reply With Quote
Old 08-25-2012, 01:41 AM   #2 (permalink)
Stoker's Avatar
I am running a 94 motor in mine with all 94 front dress. I always thought I would convert to 93 down (replace timing cover etc) if I wanted to do a major change like air conditioning. The only problem with 94-95 is that it is not very common.
MKIII 302EFI X-cam Power steering. IRS Pin drive width. SAI mod. 750 lb front 900 lb rear Konis. 7/8 front bar. Team III 17X11 17X8. Kumhos. Trick Flow Heads. Edelbrock Victor copy. 75mm throttle body.
Stoker is online now   Reply With Quote
Old 08-25-2012, 03:55 AM   #3 (permalink)
For your 94 dress kit, are you running an AC delete pulley? Wondering how your serpentine systems is setup with the dress kit.
Also, did your dress comes with only water, alternator and crank pulley? Or more?
thanks for the insight!
mm
