I have been thinking about changing my 302 (19 lb injectors) for a 347 (24 Lb. injectors). I was wondering if I have to change to another computer or buy an aftermarket chip.
Texas Cobra Club-Austin
FFR3542K, 347 C.I., Holly Systemax EFI, T-5, Modified 4-Link, Miata Front Sway Bar, Red with White Stripes
Need more info on set up. I have 24lb on my 306 so I am sure you would need more inj. What is your ECU?
My 302, harness and computer came out of an'89 Mustang. The guy I am talking to about the engine has some 35 lb. injectors he would sell with it, but I wasn't sure if I needed them or if my 24 lb. injectors would do.
I have a 70MM TB right now and I'm thinking I need a 155 pump.
With a stock computer, 24# injectors are good to around 300 or so HP. I would expect a good 347 to make considerably more power than that. 35# injectors should be good to about 450hp, with a stock computer.
I would expect you would need a new tune with the new engine. If you're upgrading, you'll probably use a "bigger" camshaft, bigger heads, and more compression. Your current tune will be fairly with your bigger injectors. But it will only be fairly close.
A custom engine needs a custom tune. There's no off the shelf or out of the can tune that will work for you. If you want to get the most from that new expensive engine - and you want it to last - pony up the bucks for a dyno tune at a good shop.
We are running the Trickflow topend package (stage 1 cam, upper/lower intake, heads) with RWHP in the ~330HP range and run stock A9L computer, 24lb injectors with MAF to match and 70MM TB. You will need a variable fuel pressure regulator.
Tony Nadalin
2012 ICSCC ITE Class Champion My Garage
Crap! The guy sold it out from under me today. But I'm still going to buy a 347, so all this info. helps in my decision making and parts gathering.
Thanks, guys.
