Head Gasket Bore Diameter - FFCars.com : Factory Five Racing Discussion Forum
Old 04-27-2012, 10:14 PM   #1 (permalink)
Eazy_P's Avatar
I have a 351w block that has been bored 0.040 over (4.040").
I will be using Cometic MLS head gaskets, but am unsure which ones I should buy since they come in 4.060, 4.080, 4.100 bore diameters. I know the gasket bore needs to be larger than the cylinder bore, but I'm not sure how much bigger I should go.
Anyone have any suggestions of which ones I should get?
FFR#7314 - MK4
8-71 Blown - 410W, TKO600, 3-Link, Konis, 3:27 rear, Stainless Sidepipes, Speedhut Gauges, Hoops & Overriders, 295's on 15's, PS, Hydroboost
Eazy_P is offline   Reply With Quote
Old 04-28-2012, 12:39 PM   #2 (permalink)
BigLeo69's Avatar
more bore on the head gaskets changes your compression ratio (CC's)
i would think that the cometic guys would have one for the 40 over
keep the compression of gasket around .040 thickness
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 04-29-2012, 12:14 AM   #3 (permalink)
Eazy_P's Avatar
Thanks Leo, I will be going with the .040 compressed gasket.
I want to keep the gasket bore diameter as small as possible, but I'm not sure if the 4.060 HG bore is big enough to cover the taper at the top of the cylinder bore or not (especially if the cylinder bores are not exactly centered). Just wondering what size head gasket bore most guys are running on a small block ford that is bored 0.030 or 0.040 over.
FFR#7314 - MK4
Old 04-29-2012, 11:40 AM   #4 (permalink)
Wade Chamberlain's Avatar
4.1"
Wade Chamberlain
FFR2229K
Old 04-29-2012, 03:07 PM   #5 (permalink)
Eazy_P's Avatar
Originally Posted by Wade Chamberlain View Post
4.1"
Thanks!
FFR#7314 - MK4
Old 05-05-2012, 06:46 PM   #6 (permalink)
Daddy-O's Avatar
Gonna catch hell for this but with the 4.020 SBF and aluminum TW heads I use Fel-Pro 4.100 / .047 gaskets.
Fel-Pro Q9333PT1 - Fel-Pro Head Gaskets - Overview - SummitRacing.com
Jonathan
Building 289 c.i.d. engines.
Daddy-O is offline   Reply With Quote
Old 05-08-2012, 12:10 AM   #7 (permalink)
why would you catch hell? That's a good gasket.
Wade Chamberlain
FFR2229K
Old 05-08-2012, 01:31 AM   #8 (permalink)
Personally I would keep the HG bore as close to the block bore as possible - in your case the 4.060" bore. The larger the HG bore compared to the block bore, the more compression you loose and the more area you have for carbon deposit build up and hot spots.
DeaconBlue is offline   Reply With Quote
