302 block rear main seal - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 9 (permalink) Old 09-05-2011, 11:41 PM Thread Starter
Brian Palmer's Avatar
Can it be replaced with the removal of the pan? I believe it's there where a leak is.
Thank you.
Brian Palmer
Brian Palmer is offline
post #2 of 9 (permalink) Old 09-05-2011, 11:54 PM
2FAST4U's Avatar
You have to remove the flywheel and clutch
Bill D
RCR GT40 - 1051P clone, $old
FFR 7991 - becoming a 289 FIA with a Mr. Bruce body, 331, Webers, T-5, IRS, Vintage Wheels pin drive wheels, and Goodyear billboards
2FAST4U is offline
post #3 of 9 (permalink) Old 09-06-2011, 12:07 AM Thread Starter
Thought so. Thank you, as always, Bill.
post #4 of 9 (permalink) Old 09-06-2011, 12:31 AM
2FAST4U's Avatar
Here Brian, this might help
How to Install a Ford 302 Rear Main Seal | eHow.com
Bill D
2FAST4U is offline
post #5 of 9 (permalink) Old 09-06-2011, 01:56 AM
Bill C's Avatar
Try replacing the pan gasket first, using some hi-temp sealer on the front and rear curved portions. I had oil dripping down the front plate of the bell housing and it turned out it was from the rear of the pan.
Bill C is offline
post #6 of 9 (permalink) Old 09-06-2011, 02:47 AM
Maybe. Early 302 blocks have a 2 piece seal. You have to remove the oil pan and rear cap, but not the trans, clutch or flywheel. This is a much easier job in a Cobra.
Newer 5.0 blocks use a 1 piece seal, that's installed from the back. You don't need to remove the pan or cap, but the trans, BH, clutch, and flywheel all have to come off. A real pain in most cars.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is offline
post #7 of 9 (permalink) Old 09-06-2011, 09:41 PM
BigLeo69's Avatar
Icon21 field verify
make sure its not the valve covers
work from the top down
wipe it clean and re-torque the covers
oil on sbf tend to drip near the rear main, its physics that drip will be at the block plate.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
BigLeo69 is offline
post #8 of 9 (permalink) Old 09-06-2011, 09:51 PM
Arch F's Avatar
As others have said, all oil leaks look like a rear main seal on a small block.
I was planing on pulling my engine next winter to replace mine. Installed a new pan and 95% of the leak went away. I am betting on the valve covers for the other 5%.
Good luck,
Arch
Arch F is offline
post #9 of 9 (permalink) Old 09-07-2011, 02:05 AM
If it is the just the pan gasket, then there are newer designed one piece molded pan gaskets out there that are really nice, such as the MrG #6683
Mr. Gasket 6683 - Mr. Gasket Oil Pan Gasket Sets - Overview - SummitRacing.com
..which is most likely just a repackaged Victor Reinz or ROL part.
DeaconBlue is offline
