Look towards the rear end of the block. There should be some form of partial VIN there. It will just look like a bunch of connect the dots. You'll need to clean it up real good to see them. If you can't make out what the numbers are, post a picture here and I'll see what I can do. Last time I tried to help a guy figure it out, I was 1 digit off from the actual numbers and that block had some horrible engraving. Hopefully yours is a lot better. If you have the VIN of the donor, it will help you make out the numbers on the block.
-Joe
"AC Cobra - America's sensational GT car." - Road & Track Road Test Annual '64
