weight difference - aluminum versus cast iron block? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 16 (permalink) Old 05-07-2008, 06:40 PM Thread Starter
Runs with scissors!
GECCO's Avatar
Send a message via Yahoo to GECCO
Doing a little daydreaming about someday swapping all my engine parts over to an all aluminum Dart block. Does anyone happen to know how much the weigh difference will be? A cast iron block weights...what? 150lbs?
I figure that plus swapping to an aluminum rear center section (IRS) would make for a real featherweight!
MKIII #6171 IRS 3.27 POSI Chrome Bullitts
FSB went BOOM!
Replaced with LS376/525 525hp 489ft/lbs
Wilwood brakes from Mr Levy (WOW!)
GECCO is offline
post #2 of 16 (permalink) Old 05-07-2008, 06:58 PM
fastLANE82's Avatar
I would say since a 347 is a bored & stroked 302 you would be looking @ less than 90 lbs and over $5 grand.
"cry havoc, and let slip the dogs of war!"
fastLANE82 is offline
post #3 of 16 (permalink) Old 05-07-2008, 08:13 PM
For the block, weight savings is about 80#. Additional cost is about $2,500.
For the diff, weight savings is about 10#. Additonal cost is about $150.
IMO, not worth it unless you're building an all out race car where every ounce counts. Or you're Bill Gates and a few extra pennies won't matter.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is online now
post #4 of 16 (permalink) Old 05-07-2008, 08:38 PM Thread Starter
Runs with scissors!
GECCO's Avatar
Definitely not Bill Gates, nor building an all out race car. Just daydreaming about future possibilities (the car's not even done and I'm already thinking about upgrades - am I addicted or what??). Being a motorcycle roadracer, I'm obsessed with weight savings - when the bike and rider as a package can weight less than 500 pounds, every once counts.
As far as dollars per pound saved, I agree it's totally ridiculous...then again, I think we can all agree that practicality pretty much went out the window when you placed the order with FFR! LoL
FSB went BOOM!
GECCO is offline
post #5 of 16 (permalink) Old 05-08-2008, 11:57 AM
Believe just changing to alum heads it safes 50 or 75lb's?
If nothing else it sure makes picking them up easyer
M III recieved 8-06, 3 link,lca's PS+PB,carb,302,373 gears, T5 first start 8/27/06.Go Kart 9/9/06
Tagged 10/24/06
Graduate 4-07
hind sight is offline
post #6 of 16 (permalink) Old 05-08-2008, 12:13 PM
trevor's Avatar
iron heads are 50# heavier than al.
a levy super duty T5 is almost 100lbs lighter than a TKO or tremec
302 is 65lbs lighter than a 351
an al. bell housing with a kevlar blanket is 30lbs lighter than a meclod bell housing
you can save at least 100lbs if you can find an old carbon body
you can save 20lbs or so with radial forged wheels or race wheels
you can save 50lbs using 3-link instead of IRS
my car weighs 2130 dry, 302, al heads, T5, al. bell housing, 8.8 rear, TeamIII wheels, V710 race tires, no interior
trevor is offline
post #7 of 16 (permalink) Old 05-08-2008, 02:35 PM Thread Starter
Runs with scissors!
GECCO's Avatar
Really? That one surprises me. I figured it was a toss-up, maybe the IRS was a few pounds (10-20) heavier (but with far less unsprung weight). I'm not saying you're wrong, but can you document that somehow?
That's pretty light! I'm curious to see where mine ends up when all is said and done.
FSB went BOOM!
GECCO is offline
post #8 of 16 (permalink) Old 05-09-2008, 12:00 AM
trevor's Avatar
Ive read it a bunch of times, of course you save 10 lbs with a al. diff. Maybe try a forum search. A lot of guys like the 3-link cobra better than IRS on the track (Levy, Dan Elam etc.). I was giving you some examples on where weight savings can be other than an aluminum block motor. You can save almost 200 lbs by using a 302 based motor, Levy super duty T5 and al. bell housing with a kevlar blanket - instead of a 351 based motor, TKO500 and Meclod scatter shield.
trevor is offline
post #9 of 16 (permalink) Old 05-16-2008, 03:06 PM
KC Wildcat's Avatar
Also, don't forget all the mods and creature comforts that add weight - do you need an oil cooler? Probably not. Leave off all the insulation, fat mat, etc. Leave off passenger rollbar, carpet, door panels. Go with light weight seats. Forget PS, PB, heater, A/C, maybe even wipers?
If lightweight is your goal, the cheapest way is by deleting things.
Oh yeah, one other thing, the driver should lose weight! (Not directed at you, but a general statement. Even Indy cars are now basing weight on car + driver because Danica is 20-40# lighter than other drivers.
Rich
KC Wildcat is offline
post #10 of 16 (permalink) Old 05-16-2008, 03:35 PM
Darren T's Avatar
A TKO is 105#. I have picked up Gordon's SD T5 and it is more than 5#.
SOLD - FFR5596RD MKIII. Recv'd 7/06 completed 6/08.
Levy Racing Stage 5 408w, MassFlo, I^2, IRS, Levy Konis, 17" FR500, Wilwood brakes.
Darren T is offline
post #11 of 16 (permalink) Old 05-16-2008, 11:36 PM
trevor's Avatar
opps
T-5 75lbs
TKO 105lbs
T-56 129lbs
there is a big weight difference between the T-5 alum. bell housing vs. a meclod scatter shield, about 40-50lb.
trevor is offline
post #12 of 16 (permalink) Old 10-20-2008, 05:32 PM
Going nowhere fast.
Michael Stora's Avatar
How much does a stock aluminum T-5 bellhousing weigh? I've seen some universal McLeods in the 45 lb range. Blankets are listed as ~5 lb. I'm guessing the aluminum bell housing would be around 20-25 pounds, wouldn't it?
President Clinton dismissed Sessions on July 19, 1993. Sessions was five and a half years into a ten-year term as FBI Director; however, the holder of this post serves at the pleasure of the President.--Wikipedia
Michael Stora is offline
post #13 of 16 (permalink) Old 10-20-2008, 10:43 PM
Forte's Parts Connection
snakeboost's Avatar
aluminum 18-20 lbs in box
quicktime 6060 25 lbs in box
quicktime 6065 29 lbs in box
also the aluminum blocks tend to weigh more or same as stk due to more strength being built into the design
that said mike has an alum block here at the shop for purchase/build = older ford block 302
snakeboost is offline
post #14 of 16 (permalink) Old 10-21-2008, 08:25 AM
al t5 bellhousing weighs 7 lbs.
vector1 is offline
post #15 of 16 (permalink) Old 10-24-2008, 11:33 PM
sedlak7's Avatar
It would and I couldn't give you a number but it is dramatic. Plus switching to dart heads is gonna give you a dramatic increase in horsepower. The flow that dart heads have is an incredible.
sedlak7 is offline
post #16 of 16 (permalink) Old 01-13-2009, 07:43 PM
cj
cj's Avatar
Send a message via MSN to cj
My car is 2250 with all the fluids in it, half tank of gas, and IRS... oh, and iron heads, I'm guessing I could get 150lbs off with better wheels and alum heads and a few other goodies.
cj is offline
