Roller cam conversion - FFCars.com : Factory Five Racing Discussion Forum
Old 03-13-2006, 03:03 AM   #1 (permalink)
What is required to convert a 73 block to a late model roller cam?
The plan:
70 302, GT40P heads, K code flat tappet cam, Webber IDAs, T5, 3.31 IRS, Torsen Diff. Make it look like Phil Hill\'s ride at Sebring in \'63
Eman is offline   Reply With Quote
Old 03-14-2006, 11:17 PM   #2 (permalink)
Pro FFR Builder and Moderator
Gordon Levy's Avatar
Roller lifter and spider from Ford. The valley pan area of the block needs to be modified. There are 2 holes that need to be drilled and tapped for the spider and 4 area's that need to be ground down so the dog bones sit flat.
2nd 2005 Nationals
Gordon Levy is offline   Reply With Quote
Old 03-14-2006, 11:19 PM   #3 (permalink)
canuck1's Avatar
Eman,
2 basic methods of doing this:
1.) small base circle cam which allows use of stock (factory style)roller lifters, lifter guides (dogbones) and retainer (spider). You must also drill two very small holes in the lifter valley for the retainer and usually grind off the casting numbers there as well as the tops of one or two lifter bores if the factory casting causes the lifter guides to bind.
2.) use a standard base circle roller cam and special "link-bar" style lifters which do away with the need for the other roller hardware.
Check with the cam manufacturer for specifics, but steel cams require a steel distributor gear as well. This covers most rollers, but some of the retrofit roller cams actually use a cast iron gear.
Option 2 is simpler, but more costly. Many people will tell you that there is not much selection in small base circle cams but this is not so since most cam manufacturers will grind any cam pattern on a small base circle for a nominal extra charge.
Either conversion option requires you take a careful look at your rocker arm geometry once assembled and make sure you are using the correct length pushrod.
Lots of good articles on this upgrade available on the web.
Cheers,
Sean
canuck1 is offline   Reply With Quote
Old 03-15-2006, 02:41 AM   #4 (permalink)
Thanks gentlemen this will get me started!
The plan:
Old 04-29-2006, 03:15 AM   #5 (permalink)
Be carefull when you drill your holes because they go into your cam brg. I found the lifter conected with bar are a safer to use on a already built engine. Just check them for clearance when you in stall the lifters. I found the oil restrictor are really not needed in most cases. This is some what like HV oil pumps. I build loose engines and have NO problems. Lot of this depends on your cam lift as well. Under .550 lift you most likely will not have any problems. Check you engine very close on trial fitting.
If guns cause crime, then pencils cause misspelled words.....author unknown
CAPTDON is offline   Reply With Quote
