73 302 for builder - FFCars.com : Factory Five Racing Discussion Forum
Old 03-03-2006, 01:34 PM   #1 (permalink)
I have in my possesion a 1973 vintage 302 from an f150. It ran well before I took it out 15 years ago. I plan on starting an FFR roadster build in the near future, would this engine be an acceptable place to start or would I be better off with a later 5.0? I've heard stories of older metallurgy being better and worse than newer. Which do I believe?
The plan:
70 302, GT40P heads, K code flat tappet cam, Webber IDAs, T5, 3.31 IRS, Torsen Diff. Make it look like Phil Hill\'s ride at Sebring in \'63
Eman is offline   Reply With Quote
Old 03-03-2006, 02:57 PM   #2 (permalink)
Pro FFR Builder and Moderator
Gordon Levy's Avatar
It really depends on which early block and what you plan on doing with the engine.
The 73 could be a Mexican block which was the best of the non-boss blocks. The standard block is better in strength than the 5.0 block but it has a 2 piece rear main seal and needs some mods to be a hydraulic roller.
2nd 2005 Nationals
Old 03-03-2006, 06:47 PM   #3 (permalink)
Gordon, I'm building a street /autox car. I feel that 350 hp would be adequate (at least initially!)I like the idea of a roller cam engine, and I am very strongly inclined to use Webbers. Where do you find the stamping to ID the place of manufacture? Are the 73 heads much different from the newer 5.0 heads?
Thanks again
The plan:
Old 03-03-2006, 07:03 PM   #4 (permalink)
The ID on the block is on the bottom above the starter. To ID a Mexican block you need to look in the valley pan area and it will say Mexico.
Buy a set of aluminum heads the stock 302 heads aren't worth anything.
2nd 2005 Nationals
Old 03-03-2006, 07:50 PM   #5 (permalink)
Gordon, how extensive are the mods to use a roller cam?
once again my thank yous, thank you
The plan:
Old 03-03-2006, 09:50 PM   #6 (permalink)
2 holes to be drilled and tapped. Some gronding in the valley pan area. It takes about an hour to do it.
2nd 2005 Nationals
Old 03-03-2006, 10:14 PM   #7 (permalink)
Gordon- Thanks again! I just checked out your website, I'm impressed. I really do appreciate the time you spend answering questions. Did I see a post that you had some heads (alum) for sale? If so how much?
The plan:
Old 03-03-2006, 10:44 PM   #8 (permalink)
That was a long time ago. Those are way gone.
I do have a set of cast iron GT 40's That I would concider selling.
2nd 2005 Nationals
