alum. heads worth the $1000+ ? - FFCars.com : Factory Five Racing Discussion Forum
Old 02-22-2006, 02:59 AM   #1 (permalink)
Just wondering if they were worth the price tag. The two advantages I see are the weight savings and of course the better flow characteristics and thus more power potential. But how much weight savings over iron and how much power? I was considering doing a 302 with a stroker kit and would be completely happy with 350hp to the ground.
So what do you say guys(or gals)?
zoomer is offline   Reply With Quote
Old 02-23-2006, 12:19 AM   #2 (permalink)
Porxter's Avatar
I believe the weight saving is about 25 lbs per head.
Sounds like you already know the rest - the stock valves and ports are the power-limiters on SBF's.
Two main ways to overcome this:
1. Better heads
2. Force the air through the small valves and ports with a blower.
More HP = more [img]graemlins/money.gif[/img]
Steve [img]graemlins/red.gif[/img]
FFR4776, Ford Performance Red, Arctic White Stripes, Balanced 5.0L, TRW forged pistons, Cobra intake, “F” Cam, 1.6 Roller Rockers, 24lb injectors, BBK 70mm TB & EGR, Calibrated Vortech 73mm MAF, 190 LPH Holley, 8 Qt. Canton S/S Pan, RAM Clutch & Steel SFI Flywheel, SFI Damper, Ceramic 4 into 4's, Underdrive pullies, T5Z, B&M shifter, 3-link 8.8 w/3.55's & Granatelli Girdle, Tubular control arms & coilovers, Halibrand style wheels.
Porxter is offline   Reply With Quote
Old 03-01-2006, 01:05 AM   #3 (permalink)
Another element that I learned is that the heat transfer characteristics will allow a higher compression ratio with pump gas than the iron heads. My engine guy is saying that close to 10 is a good number.
Still learning
[img]graemlins/grey.gif[/img]
StephenP is offline   Reply With Quote
Old 03-02-2006, 04:09 PM   #4 (permalink)
Porxter's Avatar
StephenP,
That is true, I forgot to mention that other benefit.
They claim you can go up a full compression point - all else remaining the same.
In other words, an engine with a certain combintion that would need 8.5 : 1 compression to keep form pinging, etc. could move up to 9.5 : 1 because of the rapid heat dissipation of aluminum heads.
I also posted some more info on this thread, along with many others:
http://www.ffcars.com/cgi-bin/ultima...7573/p/1.html?
