Valve spring recommendation - FFCars.com : Factory Five Racing Discussion Forum
Old 11-21-2005, 07:22 PM   #1 (permalink)
I am putting together a 5 litre roller motor for my TVR and I purchased some new gt40p heads and a e303 cam. I have the forged pistons and will be using carberation. I am wondering if roller rockers will clear cobra valve covers and if the E7TE springs would be adequate.
Cheers
Stan
vstn is offline   Reply With Quote
Old 11-22-2005, 12:30 PM   #2 (permalink)
powerhouse's Avatar
you will definately need new valve springs. You will probably end up clearancing the covers for the roller rockers. You will need to do a mock assembly and check the clearance. Andrew
powerhouse is offline   Reply With Quote
Old 11-22-2005, 05:10 PM   #3 (permalink)
Spring choice depends on cam choice. Use whatever the cam manufacturer recommends.
Some roller rockers will fit, and some won't. Like Andrew said, you'll just have to do a mock up and see. You may be able to use two cork gaskets to avoid modifying your covers.
Dart 427W, Momar 8 Stack EFI, 600'ish hp, TKO, 3.55 TruTrac, Red with Ghost Flames. More fun than should legally be allowed.
