My buddy and I started his motor for the first time today. It runs, but it's not right. Here are the symptoms:
1. It runs very hot.
2. First I set the timing by ear. When I checked it with the light, it was at about 40 degrees BTC. As I rotate the distributor to retard it, by the time I get it down to about 20 degrees BTC it starts spitting up through the carburator and won't run.
3. Tried moving the distributor over a tooth. We obviously had to rotate the distributor to re-time it (again by ear), when we measure it, it was still back at 40 degress.
Any ideas?
The motor was professionally built. 351 with AFR heads, Edlebrock carb, MSD ignition.
Mk III non-donor build, 302 EFI w/AFR165\'s, X cam, 4-into-4\'s, 3-link, delivered 12/6/04, first go-kart ride on 3/31/05. Finished August 2005 (yeah, like they're ever really finished.)
