351W - FFCars.com : Factory Five Racing Discussion Forum
Old 03-03-2005, 04:43 PM   #1 (permalink)
Question
what yr was 351W first made?
PURE AMERICAN KNOWHOW is offline   Reply With Quote
Old 03-04-2005, 12:22 AM   #2 (permalink)
turbodon's Avatar
1969
turbodon is offline   Reply With Quote
Old 03-16-2005, 06:52 AM   #3 (permalink)
Don, I heared that some years were better for the 351W block. Mine is a D4AE block. Thats a 1974 right ? I also have a 1969 block that is part of a very nicely running motor.
The D4AE is in my FFR Coupe. Its been stroked to a 418W by speedomotive with 70cc combustion chambers in Victor Jr. heads. It needs a Harmonic Balancer, and I ordered one from Summit. Its a 28.2 OZ externally balanced damper, but it has a removable weight that I will remove because my 351W (418W) is internaly balanced. Does that sound right to you ?
David
David from Tri Cities is offline   Reply With Quote
Old 03-16-2005, 09:13 PM   #4 (permalink)
turbodon's Avatar
David
The D4AE is the same block I have. It is the last yr of the good blocks 1974 other than a new race block.
It sounds like you are correct on the balancer. If you have the bob weights etc from the previous balance, a good shop will know if you have to take away or add to the bare balancer. A good shop can take the old balancer and make the new the same weight.
Remember on the older blocks the deck height was shorter before 1974.
Old 03-19-2005, 03:37 PM   #5 (permalink)
If your looking to buy a 351w I have a short block for sale $400.00 with 8.1/2 to 1 compression.It is a older block but with the rollor conversion.I had it in my 95 stang with a blower the motor has 5000 miles and 500 with blower on it.
Thank you,
Kevin Willis
Discount Tire Direct
1-800-707-8473 ext 431
KWillis@Discounttireco.com
Kevin@DiscountTireDirect is offline   Reply With Quote
