351w oil leak - FFCars.com : Factory Five Racing Discussion Forum
Old 01-31-2005, 12:36 AM   #1 (permalink)
I have about 1 hour total run time on my 351w that I purchased from the Engine Factory over 2 years ago.The block # is indicative of coming from a 1979 Ford Galaxie.The problem is I found
oil on the inside of the altenator/harmonic balancer March crank pulley.The front main oil seal area is free of oil.Is it possible that oil
may be coming through the front of the crank where the harmonic balancer is bolted to it?
Any ideas?
By the way Gordon, the door panels I purchased from you look great.
DAVES COBRA is offline   Reply With Quote
Old 02-01-2005, 06:37 PM   #2 (permalink)
Dave,
Does your 351 have the oil dipstick on the front of the engine? If so check that. I had a similar problem with a 302 that had the dipstick hole in that location
Bob Covell
FFR3931k Mk II
NCPainter - Black with grey ghost stripes
Dropped Butt Mod
302 with GT-40 heads, E303 cam, carb
IRS with 3.73 gears
Bob Covell is offline   Reply With Quote
Old 02-02-2005, 05:39 PM   #3 (permalink)
Yes it does and I will check it out.
Thanks.
Old 02-04-2005, 04:55 AM   #4 (permalink)
turbodon's Avatar
Dave
The front harmonic ballancer should be sealed with a little silicon under the washer . Oil can leak out thru the crank pin slot of the ballancer.
turbodon is offline   Reply With Quote
Old 02-06-2005, 01:47 AM   #5 (permalink)
Don
Makes sense.Thanks for the input.
