Has anyone put together a 390/428fe with stock bellhousing and clutch...how did you set it up with the clutch fork...Its my understanding that its the reverse of how a 302 is. (Pulls from the back not front.)
Mike Forte [forum vendor] has a nice setup with a push type hyd slave. I went with a stock setup and a willwood pull slave and custom bracket behind the stock fork. Sorry no picks, but it works fine and only cost $200 complete. I had bell, fork, and flywheel. I got the clutch from Mike to fit the TKO 600. Others have used an engine mounted slave using the 2 bolt holes on the block lower left corner that looks good too. Convincer has one. Maybe he will chime in.
Wayne
sorry wasn't clear...also using the Mustang pedal box set up for cable
my mk3 manual only really shows the 460 with Lakewood housing...I have Fe with Stock housing!
Im also useing a mustang pedal box. I took the quarant [plastic crap] off and turned the shaft 180 deg then put the pedal back on. Then mounted a tilton master cyl on the firewall. Hooked it up with a clevis and pin after drilling a hole through the part of the clutch shaft the plastic crap was on. The only problem with it is a brake booster will not fit past the master. Sorry about no pics. We didnt go on the forum until we were done and never thought about them.
Wayne
i am working on building a ground up pro touring 67 fairlane. planning on a 460 stroker 521 bbf. going with a t-56 magnum transmission and a mcleod twin clutch. my quesion is what is the gear tooth size flywheel that i should go with and bellhousing to mate up th correct starter. i have heard that big block fords are normally 184 tooth count
Reason: spelling
