fe lower radiator hose? - FFCars.com : Factory Five Racing Discussion Forum
Old 05-10-2012, 09:38 PM   #1 (permalink)
ff cobra master craftsman
wrench87's Avatar
Icon21 fe lower radiator hose?
what are people using for the lower hose on a fe build?, i was hoping to use breeze's lower hose but called today and it is on backorder.
mkIII picked up 9-10-04 completed
9-05 445fe stroker 750 quick fuel q series
tremec 3550 irs ffr fuel cell cobra brakes non donor build black no stripes.
wrench87 is offline   Reply With Quote
Old 05-10-2012, 09:40 PM   #2 (permalink)
FFR stainless hose.
Non-donor build MKIII, 445FE with a .82 TKO-600 mid-shift conversion, and a 4-Link 3.08 rear end. Quickfuel 850 cfm carb, MSD ignition, Koni coilovers, FFR500 wheels and Autometer Cobra Gauges.
snapperlr is offline   Reply With Quote
Old 05-10-2012, 09:55 PM   #3 (permalink)
wrench87's Avatar
Icon21
i still have my corrigated steel hose on from my small block , but the fe waterpump oultet is 2 1/4 what did you use to hook it up?
Old 05-10-2012, 10:25 PM   #4 (permalink)
AUME2010's Avatar
Breeze.... when the corrugated hose popped off and dumped my coolant in the floor i justified the Breeze unit. Real quick like.
Delivered 8/10/2010
Graduate Auburn 12/13/2010!
First Go-Kart 12/18/10
Paint 7/3/11
On the Road 11-11
WAR EAGLE!!!!
AUME2010 is offline   Reply With Quote
Old 05-11-2012, 12:00 AM   #5 (permalink)
I apologize for the slight thread hijack, but would this lower hose work for the 460? I believe the size is right, just not sure of the location of the water pump inlet on the FE.
Wicked96SS is offline   Reply With Quote
Old 05-11-2012, 12:20 AM   #6 (permalink)
wrench87's Avatar
the 460 outlet appears to be in the same location, do you know the size of the outlet?.
also you did not give a part number.
Old 05-11-2012, 02:24 AM   #7 (permalink)
I hope I'm not mis-speaking, but I'm talking about the inlet, the actual tube on the water pump. I believe the outlet is the thermostat housing on the intake. Is that right? I've dealt with LT1's for a while, and they were reverse, so, I could be getting confused. It wouldn't be the first time!
Either way, the 460 stock water-pump tube that attaches to the lower radiator hose is 2".
MODIFIED: The part number I was referring to was Breeze Automotive 70617, http://www.breezeautomotive.com/deta...=697&cat_id=17
Last edited by Wicked96SS; 05-11-2012 at 02:59 AM.. Reason: Added part number and link
Old 05-11-2012, 11:08 AM   #8 (permalink)
wrench87's Avatar
the fe is 2.125 so you would have to put a piece of rubber over the waterpump to make up the difference or get a different hose, also it depends on what radiator you have. i think they fabricate this to work with the ffr afco radiator. i have the ron davis radiator and the outlet comes off the side of the tank and makes a 90 as the afco comes straight off the tank.
Old 05-11-2012, 02:16 PM   #9 (permalink)
Mark Ames's Avatar
I used a Hose from autozone from a V10 Dodge Ram
I needed to use a FFR hose kit reducer shim at the radiator but seems to have worked well
Mark Ames is offline   Reply With Quote
Old 05-11-2012, 05:52 PM   #10 (permalink)
wrench87's Avatar
mark what year dodge ram?
