any fe install tricks? - FFCars.com : Factory Five Racing Discussion Forum
Old 04-27-2012, 04:18 PM   #1 (permalink)
ff cobra master craftsman
wrench87's Avatar
Icon21 any fe install tricks?
so i got my motor mount issue solved, try to install the transmission there does not seem to be any way to get the tranny in once the engine is already in place. has any one ever pulled a tremec transmission on a mkIII with a ford fe on a finished car looking for any tricks, if not looks like i will have to pull the engine back out.
the reason i installed it with out the tranny i figured it would be easier to handle because i was by myself.
mkIII picked up 9-10-04 completed
9-05 445fe stroker 750 quick fuel q series
tremec 3550 irs ffr fuel cell cobra brakes non donor build black no stripes.
wrench87 is offline   Reply With Quote
Old 04-27-2012, 04:25 PM   #2 (permalink)
Mark Ames's Avatar
I installed mine with Tranny on back of engine and it was easy.
Even if its possible to install the tranny, I would suggest its easier to pull the engine at this stage.
Mark Ames is offline   Reply With Quote
Old 04-27-2012, 08:28 PM   #3 (permalink)
wideglidejoe's Avatar
Installed engine/tranny together, wouldn't even consider anything else.
Wideglidejoe
FFR#6143 Mk III: FE 455" w/TKO 600 .82, IRS w/3.27's, 17" Team III's w/245/45's & 315/35's. Gas N pipes.
Picked it up end of Aug '08
First start 5-12-10
First go kart 5-26-10
wideglidejoe is offline   Reply With Quote
Old 04-27-2012, 10:07 PM   #4 (permalink)
wrench87's Avatar
Icon21
what did you guys use to install the engine and tranny together?, i am using a engine lift platethat mounts to the carb flange,if you used this which hole did you use?.
when you installed it did you have a helper it seems like a lot of wait to muscle around.
Old 04-27-2012, 10:09 PM   #5 (permalink)
wrench87's Avatar
Icon21
i forgot to ask my engine hoist has extendable legs but it seems to hit the jackstands, i just made some 5 inch wood structures so i can place them under the front tires so i have enough room for the engine hoist to slide under the frame. what did you use when you installed your engines?.
Old 04-27-2012, 10:21 PM   #6 (permalink)
Wrench,
It is easier to do as one assembly, but also easy to do separately if you have a lift and tranny jack. I have done both. If you do them together an engine leveler helps a lot. If you do them separately you can remove the the tranny bracket and install the tranny tailshaft up first. It goes up easily then. After 3 times now I am getting good at it.
Non-donor build MKIII, 445FE with a .82 TKO-600 mid-shift conversion, and a 4-Link 3.08 rear end. Quickfuel 850 cfm carb, MSD ignition, Koni coilovers, FFR500 wheels and Autometer Cobra Gauges.
snapperlr is offline   Reply With Quote
Old 04-28-2012, 11:15 AM   #7 (permalink)
Wrench,
Attached are some photos for the install. It was definitely a 3 person event. I thought it could be done with 2, but one person is managing the transmission, the other is pushing the engine into the engine bay, while the other is managing the jack, moving it forward, lowering the engine etc. I bought additional chain to increase the length and hooked it in the front most hole. Once the transmission was in the tunnel, I need a jack to lift it. You will need to move the jack stands to sit underneath the tube that runs from left to right rather than the tubes that run along the length of the car. The pictures mostly show my wife and neighbor installing the engine. I'm the one moving the jack around.
gyow is offline   Reply With Quote
Old 04-28-2012, 11:44 AM   #8 (permalink)
wrench87's Avatar
this is the problem my car has the body on, last night i made some wood structures that i can place under the front tires. i thought about it last night that i could put the stands under the front left to right 4 inch tube.
i still would like to just lift the engine and pull it back and try to get the tranny in, i get nervous hanging all that weight over a finished body, i remember when i installed my 342 with the tranny attached with the body off it was difficult because you have to get it so high and tranny angled down because of the position of the x brace and i was by myself.
Old 04-28-2012, 05:29 PM   #9 (permalink)
A load leveler helps a lot if you do it all together.
Old 04-28-2012, 11:48 PM   #10 (permalink)
Non-whiner
Mark Reid's Avatar
Using an engine leveler you can do it by yourself and it is relatively easy, just takes some time. Don't even try to do it by yourself without one.
Here's my wife installing the 427w in my cobra:
FFR coupe #190 SOLD
1966 Bronco w/289 and 3 speed
Unknown
Mark Reid is offline   Reply With Quote
Old 04-29-2012, 12:25 PM   #11 (permalink)
It's a 1 person event with an engine tiller and the nose off the ground 2-3 feet, with the tranney installed
BostonBuster is offline   Reply With Quote
Old 04-29-2012, 03:42 PM   #12 (permalink)
wrench87's Avatar
Icon21
I tried again this morning there is no way to get the tranny far enough back the shifter gets in the way. I will have to remove the engine and install the tranny.
The next qustion the cylinder heads only have bolt holes on the drivers side front and the passenger side rear can i still use the leveler with only 2 pick up points?.
also has any one used the harbor freight load leveler?, they are only 40.00, i hate renting it always seems something breaks then you own it. who else sells a cheap load leveler?
Old 04-29-2012, 06:52 PM   #13 (permalink)
The short answer is no but you can still use 4 mount points.
On the passenger side front, use one of the alternator mounting holes. On the driver's rear, remove the bolt at the 10 oclock position that holds the bell housing in place. You can easily reinstall the one bellhousing bolt you removed when you're done.
Here you can see where we used the alternator bolt:
Bruce
FFR 6795, Delivered 10/26/08, 390FE Stroked to 447, Carb, T56, IRS, Pin Drive, 15" wheels, 3.55 gears
sharkx is offline   Reply With Quote
Old 04-29-2012, 07:24 PM   #14 (permalink)
Exactly what Bruce said on the bolts and I used the Harbor freight leveler with no problems. I did need longer chains though.
Old 04-29-2012, 10:58 PM   #15 (permalink)
wrench87's Avatar
Icon21
I will pick up a load leveler and give it a try, it is a shame because the engine is sitting in the car here is a pic.
Old 04-30-2012, 12:36 AM   #16 (permalink)
Wrench,
Is that a full length oil filter or a short one?
Old 04-30-2012, 02:19 AM   #17 (permalink)
wrench87's Avatar
Icon21
that is the short filter, it does not even look like it will come off it is that close to the frame?
Old 05-01-2012, 02:41 PM   #18 (permalink)
wrench87's Avatar
Icon21
ok i picked up a harbor freight 2 ton load leveler, it is raining today so i cant try to install the engine the garage is not long enough so car has to be 3/4 out side, no room to do from side. i already see a problem with the body on you loose a lot of room if you pick up the engine from the rear of the cyl head and bellhousing the chains will hit the body?
i noticed all the pics you guys had the body off, except for mark reid but he has a small block. if i would of known this was such a headache i would of kept my 342.
Old 05-02-2012, 02:03 AM   #19 (permalink)
Check out this thread where Kirkham installs an FE with the body on it. It is a long thread, but it's there with a picture showing how it can be done.
http://www.clubcobra.com/forums/kirk...ly-manual.html
Sent from my Autoguide iPad app
Old 05-02-2012, 02:50 AM   #20 (permalink)
fe install
Hi i have done it 2 times with a late mark1, i had to tweek the top trans panel a touch, first time 428 second 427s/o both times not a scratch on the paint just take your time it will be worth it.
regards Bob
ffr3226 427 s/o done Sold
ffr1922 FIA conversion SB webbers now done sold
1965 F/B and 1966 Coupe on the way sold
1966 CAVGT40 gulf colors 331 with webers sold
1966 contemporary cobra 427 S/O guardsmen blue with white stripes sold
BAUTO is offline   Reply With Quote
Old 05-02-2012, 11:54 AM   #21 (permalink)
wrench87's Avatar
Icon21
i think one thing that would of helped would of been to use the short input shaft and the 6057 bellhousing, this would of given a little room to possibly install the tranny afterwards.
i read the kirkham article, they did not have the tranny tunnel in so that made it a lot easier, it was wierd how they hooked up the engine from the side .
i will give it another try with the load leveler once the wheather clears up.
Old 05-02-2012, 10:19 PM   #22 (permalink)
wrench87's Avatar
Icon21
ok i got the engine in with transmission, this was not fun at all by yourself. i was correct about the load leveler the chains would of hit the body near the windshield, i was lucky enough to have the oil pan rest on the x brace so i could take the tension off the load leveler and pick it up from the engine plate that bolts to the carb. i was nervous with all that wait hanging over my black paint job. i did notice i have to trim off a little where the shifter hole is when i put it in first it just hits the aluminum, and the tranny mount only lines up with the middle hole so i will have to enlarge the left and right hole for the mount to bolt up. now i hope the headers fit in the cut outs.
Old 05-02-2012, 10:34 PM   #23 (permalink)
Don't worry to much on the exhaust, you may have to enlarge the anyways because the fe will build alot more heat and start to blister the paint, ask me how i know
regards Bob
Old 05-02-2012, 11:21 PM   #24 (permalink)
wrench87's Avatar
Icon21
when i ran my 342 i had ffr cats, then i ran the j pipes so you had alot of adjustment.
i tried a set of 4x4's and they did not even come close to the openings i had to heat them up and tweek them to fit the openings, i had bought them at the ffr open house they were cheap because they had marks in them from the bends so i did nt care to much.
so now i have to add a relay for the fuel pump termintate the wires for the msd , shorten the wires to the starter, figure out how to hook up the carb throttle cable, and plumb in the new fuel pressure regulator (return style) and make up some new fuel lines in the engine compartment.
Old 05-03-2012, 12:56 AM   #25 (permalink)
Wrench,
Glad to see you got it done. I also enlarged the cut outs at the rear of the opening because of heat. How did the clutch linkage work out?
Old 05-03-2012, 02:11 AM   #26 (permalink)
Originally Posted by snapperlr View Post
Wrench,
How much gap did you leave between the exhaust and the body? Can you post pics?
