fe expansion tank question - FFCars.com : Factory Five Racing Discussion Forum
Old 04-17-2012, 02:21 AM   #1 (permalink)
ff cobra master craftsman
wrench87's Avatar
Icon21 fe expansion tank question
will this expansion tank work on a ffr?, i am wondering if the cap location would hit the hood?.
mkIII picked up 9-10-04 completed
9-05 445fe stroker 750 quick fuel q series
tremec 3550 irs ffr fuel cell cobra brakes non donor build black no stripes.
wrench87 is offline   Reply With Quote
Old 04-17-2012, 02:30 AM   #2 (permalink)
Steve,
That's the same tank I have. It works fine. I thought about your question on the mounts. Do you know if thr FFR frame mounts are different for the big block and small block? For some reason I thought some were different.
snapperlr is offline   Reply With Quote
Old 04-17-2012, 02:53 AM   #3 (permalink)
fe tank
Hi, some of those tanks need to be modified, the one on my contemporary had almost an inch removed from the neck. i would do a dry run before adding coolant
regards Bob
ffr3226 427 s/o done Sold
ffr1922 FIA conversion SB webbers now done sold
1965 F/B and 1966 Coupe on the way sold
1966 CAVGT40 gulf colors 331 with webers sold
1966 contemporary cobra 427 S/O guardsmen blue with white stripes sold
BAUTO is online now   Reply With Quote
Old 04-17-2012, 11:29 AM   #4 (permalink)
wrench87's Avatar
Icon21
yes the mounts are different for the small block and big block, on the small block i used energy suspension poly mustang motor mounts. i purchased this expansion tank at the thompson speedway flea market a few years back it looked almost new.
what height should the tank be at using the dis cap as a reference?
Old 04-17-2012, 12:14 PM   #5 (permalink)
This should help:
This was mine with a straight edge along the frame. It was concerned but it fits just fine.
Bruce
FFR 6795, Delivered 10/26/08, 390FE Stroked to 447, Carb, T56, IRS, Pin Drive, 15" wheels, 3.55 gears
sharkx is offline   Reply With Quote
Old 04-17-2012, 12:55 PM   #6 (permalink)
Sorry, I wasn't very clear. For some reason I thought the frame itself was little different when comparing a big block to a samll block, but I am not sure. Hopefully someone can answer that.
Old 04-17-2012, 01:45 PM   #7 (permalink)
That is the same one I am using too. Make sure to pressure test it. I am on my third one including two new ones and just fixed it again.
Wayne
MK3,FE427-6V,TKO,IRS,Dual Heaters,Heated Seats
toolerwayne is offline   Reply With Quote
Old 04-17-2012, 05:00 PM   #8 (permalink)
wrench87's Avatar
on the ffr the frames are all the same so is the engine mounts, what is different is the actual mounts that mount to the engine.
Old 04-18-2012, 11:55 PM   #9 (permalink)
wrench87's Avatar
Icon21
well i am glad i took the advise to get the tank pressure tested, it has a hairline crack near a seam the place wants to charge 40.00 to fix?.
Old 04-19-2012, 05:05 PM   #10 (permalink)
Not surprised. I now use a 7lb cap with a canton overflow can.
Wayne
Old 04-20-2012, 11:37 AM   #11 (permalink)
convincor's Avatar
If you get tired of fixing old....
Bird Nest 1958-66 Ford Thunderbird Parts
2012 Street glide,103
Old 04-20-2012, 12:52 PM   #12 (permalink)
wrench87's Avatar
I found a site that sells the early and late ones, Pat Wilson's Thunderbird Parts.
they show them for 199.00 each.
convincor, do you know of anybody that would have a set of the ffr motor mounts?
i have mike forte's mounts they dont work, ffr is out of stock and the guy that makes them is on vacation i am at a standstill.
Old 04-20-2012, 12:59 PM   #13 (permalink)
convincor's Avatar
The link I posted has same and same price...
If you can find someone with a right hand mount, I have two lefts..
Old 04-20-2012, 02:14 PM   #14 (permalink)
I bought two from Bird Nest. Both leaked. They were good about replacing the first one. The next time I fixed it myself so I could silver solder it. I saw a nice aluminum one on a superformance, but he said it was $500. The shop I use at work says they disassemble them, sand blast and reassemble your part.NE Radiator Southbridge, Ma. 508-765-5583 .A lot of these are made in china now.
Wayne
Old 04-21-2012, 02:34 AM   #15 (permalink)
wideglidejoe's Avatar
I used one off of a 63 Galaxie 390. It fits just fine w/o any mods.
Wideglidejoe
FFR#6143 Mk III: FE 455" w/TKO 600 .82, IRS w/3.27's, 17" Team III's w/245/45's & 315/35's. Gas N pipes.
Picked it up end of Aug '08
First start 5-12-10
First go kart 5-26-10
wideglidejoe is offline   Reply With Quote
