Radiator hoses - FFCars.com : Factory Five Racing Discussion Forum
Old 03-09-2012, 12:36 PM   #1 (permalink)
Mark Ames's Avatar
Radiator hoses
What did everyone use
I am running a 390fe with tank to a afco radiator.
The supplied FFR stainless tube is useless, can regular hoses be clamped to the stainless tube in place of the rubber eleeves that don't fit.
Really cant justify spending $210 for the breeze pieces.
Mark Ames is online now   Reply With Quote
Old 03-09-2012, 12:53 PM   #2 (permalink)
ff cobra master craftsman
wrench87's Avatar
Icon21
i am curious to i have not installed my 445fe yet but i have a ron davis radiator and mike forte's degas tank. mark are you saying the stainless steel set up wont work? is that on the lower also?
mkIII picked up 9-10-04 completed
9-05 445fe stroker 750 quick fuel q series
tremec 3550 irs ffr fuel cell cobra brakes non donor build black no stripes.
wrench87 is offline   Reply With Quote
Old 03-09-2012, 01:02 PM   #3 (permalink)
Mark Ames's Avatar
The water pump inlet is waay to fat for the FFR supplied hoses.
Old 03-09-2012, 04:29 PM   #4 (permalink)
Mark Ames's Avatar
I just spent 20 mins at autozone looking at all the hoses they have available...
There was one which looks like its very close to what I want for the lower and its one piece.
Will mock up and if any look interesting will post pictures and part numbers.
Old 03-09-2012, 09:49 PM   #5 (permalink)
AUME2010's Avatar
Save yourself the headache and buy from Breeze. It sucks paying that much, but they look and work very well when installed. After having the stainless hose just pop loose one time and dump all my coolant on the ground while idling in the shop i managed to justify the lower hose real quick. I don't advocate buying a lot of the stuff that some people sell that can be easily done yourself, but this is one of the few that i do. You are basically buying the steel tubing they have bent/flared/coated, the hoses aren't anything special just regular stock hoses.
Delivered 8/10/2010
Graduate Auburn 12/13/2010!
First Go-Kart 12/18/10
Paint 7/3/11
On the Road 11-11
WAR EAGLE!!!!
AUME2010 is offline   Reply With Quote
Old 03-09-2012, 10:37 PM   #6 (permalink)
I second the Breeze hoses. Buy them and forget it.
Old 03-12-2012, 04:53 PM   #7 (permalink)
Mark Ames's Avatar
I found a Dodge Pickup hose for a V10 engine which looked perfect. It is a great fit.
The hose is 2 inch wide and the length and shape are perfect. On the radiator lower outlet, I needed to use the FFR supplied spacers and two clamps, very very happy so far with how it looks and fits.
For the upper, I used the stock 87-93 mustang upper hose with a adapter I found on ebay for $12.00. The aluminum adapter allows me to install a Sender unit for the fan which is nice
All in all my hoses and adapter came to about $55.00.
I will post part numbers
Old 03-22-2012, 03:49 AM   #8 (permalink)
I am interested in the hose numbers your referenced.
Thanks.
snapperlr is offline   Reply With Quote
Old 03-23-2012, 04:30 PM   #9 (permalink)
Mark Ames's Avatar
32mm Water temp Sensor Adaptor Gauge Radiator Hose Adaptor NEW USA Ship Ready | eBay
This is the upper adapter I used. will look for the hose numbers tonight and post
Old 03-25-2012, 02:31 PM   #10 (permalink)
Yes they can
BostonBuster is offline   Reply With Quote
Old 05-02-2012, 12:16 AM   #11 (permalink)
How did it go? Does it work?
gyow is offline   Reply With Quote
