Alternator Wire Routing - FFCars.com : Factory Five Racing Discussion Forum
Old 03-20-2011, 08:43 PM   #1 (permalink)
bcw
bcw's Avatar
I am looking at how I have my Ron Francis alternator wire routed. It doesn't look like it will reach the Alternator. I'm afraid if I run it loose it will hit up against the headers. I'm just wondering where/how everyone else is running their alternator wire.
FFR 7342 MK4 Received 11/05/2010.
428CJ / TKO600 / IRS / Pin Drive / 15" Vintage Wheels
First Start 9/7/2011 http://www.ffcars.com/forums/17-fact...yser-show.html
Gokart 9/8/2011 http://www.ffcars.com/forums/17-fact...art-video.html
"If a little is good, more is better, too much is just enough" CS
bcw is offline   Reply With Quote
Old 03-20-2011, 11:26 PM   #2 (permalink)
AUME2010's Avatar
I ran mine out the firewall just behind the pass side firewall. At first i used stock brackets and run under the headers, it just barely reached, had to stretch. Now i have March brackets and I can lay it across the intake right next to the valve cover and it reaches just right. HTH
Delivered 8/10/2010
Graduate Auburn 12/13/2010!
First Go-Kart 12/18/10
Paint 7/3/11
On the Road 11-11
WAR EAGLE!!!!
AUME2010 is offline   Reply With Quote
Old 03-21-2011, 12:05 AM   #3 (permalink)
On the Mk4 I found that the RF alternator and solenoid wires were short for my desired routing (around rather than on top of the engine) so I extended them. Took them between the dash and firewall then out on the passenger's side and went forward along the upper square tube:
Here you can see that the wires are kept well above the headers before connecting to the alternator. You'll also see that I did a front mounted battery on this car and placed the solenoid on the front of the motor mount perch:
Good luck,
jeff
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 03-21-2011, 12:48 AM   #4 (permalink)
bcw
bcw's Avatar
At least I know I'm not the only one who had an issue with it. Those photos really help. I think that I'm going to re-route mine through the passenger side firewall also. Very clean setup Jeff. Thanks guys.
