Big Power Coyote Build... - FFCars.com : Factory Five Racing Discussion Forum
 1Thanks
  • 1 Post By Mark Gearhart
post #1 of 28 (permalink) Old 11-28-2016, 08:39 PM Thread Starter
Send a message via AIM to Mark Gearhart
Here's a little preview, though disregard the induction. Not going in my Challenge car but hopefully another Factory Five project for 2017 . Goal will be between 1300-1500 horsepower and be completely streetable.
FFR Challenge Street Car Build
625hp N/A Coyote, T-56 Magnum, Moser Solid Axle, etc
My Build Thread:
Mark Gearhart is offline
post #2 of 28 (permalink) Old 11-28-2016, 08:42 PM Thread Starter
Sleeving the block
My Build Thread:
post #3 of 28 (permalink) Old 11-29-2016, 01:08 PM
TMScrogins's Avatar
Mark,
You do have that same ITB induction setup in your challenge car still, correct? Are you still happy with it?
Sent from my SAMSUNG-SM-G920A using Tapatalk
TMScrogins is online now
post #4 of 28 (permalink) Old 11-29-2016, 01:28 PM
Mustang Man's Avatar
You bastard, you're building a new Gen 3 Coupe aren't you....
FFR5310RD
Mustang Man is offline
post #5 of 28 (permalink) Old 11-29-2016, 03:26 PM Thread Starter
Yep, Roger's ITB system is still working awesome.
Originally Posted by TMScrogins View Post
Mark,
My Build Thread:
post #6 of 28 (permalink) Old 11-29-2016, 03:27 PM Thread Starter
LOL, nothing locked down right now, just dreaming.
My Build Thread:
post #7 of 28 (permalink) Old 11-29-2016, 06:14 PM
q4stix's Avatar
I assume you're going FI instead of NA on this one.
Or are you going extra clever and building a big plenum over the ITB's?
Future Gen 3 Type 65 Coupe builder
q4stix is offline
post #8 of 28 (permalink) Old 11-29-2016, 09:30 PM Thread Starter
It will be a sheet metal, traditional multi port style manifold with boost.
My Build Thread:
post #9 of 28 (permalink) Old 01-04-2017, 03:58 PM Thread Starter
Story on the block sleeving. Building the engine the first week of Feb. How to Prep a Coyote Block for 1,000 Horsepower - Hot Rod Network
My Build Thread:
post #10 of 28 (permalink) Old 01-06-2017, 03:57 PM
Thomas W's Avatar
Mark,
If I was going to do a mega hp turbo build, that new Gen 3 Coupe would be the ticket. I have seriously thought about it. That would be awesome if you can make it happen. Cheers.
Thomas
FFR 4031K, twin-turbo dart block 331, AOD, 144.91 mph in the 1/4 mile
Thomas W is offline
post #11 of 28 (permalink) Old 01-10-2017, 12:54 AM Thread Starter
That's the hopeful goal - we will see how it pans out. Building the motor in 3 weeks.
Originally Posted by Thomas W View Post
Mark,
Thomas
My Build Thread:
post #12 of 28 (permalink) Old 01-13-2017, 07:58 PM
Thomas W's Avatar
Please please keep us posted. Cheers.
Thomas
Thomas W is offline
post #13 of 28 (permalink) Old 01-28-2017, 12:05 AM Thread Starter
I got the first set of our new Wiseco BoostLine connecting rods, and of course, mated to a set of JE customs that feature EN plating, skirt coat, and a thick wall DLC coated pin. Plus JE Pro Seal head gaskets. Building the motor next Wednesday.
My Build Thread:
post #14 of 28 (permalink) Old 02-07-2017, 08:45 PM Thread Starter
Engine is done. Dynoing it in about 1.5 months.
My Build Thread:
post #15 of 28 (permalink) Old 03-06-2017, 07:27 PM Thread Starter
A little sneak peek of getting it ready. It will be on the dyno the end of April.
My Build Thread:
post #16 of 28 (permalink) Old 03-07-2017, 12:17 AM
q4stix's Avatar
Looks sharp!
q4stix is offline
post #17 of 28 (permalink) Old 03-09-2017, 03:10 AM
Thomas W's Avatar
What happened to getting it dynoed this month, oh well.
Thomas W is offline
post #18 of 28 (permalink) Old 03-09-2017, 08:30 PM Thread Starter
I was trying, but this is a side project and I got busy at my real job. I want to make sure everything is right and ready to go, and not rush it.
My Build Thread:
post #19 of 28 (permalink) Old 03-10-2017, 05:10 PM
Thomas W's Avatar
Sorry, I'm just anxious to see how this pans out. Cheers.
Thomas W is offline
post #20 of 28 (permalink) Old 03-14-2017, 11:34 PM Thread Starter
Story is up finally - How to Build A Bullet-Proof Coyote Engine For 1000-Plus Horsepower - Hot Rod Network
My Build Thread:
post #21 of 28 (permalink) Old 03-15-2017, 03:16 AM
Thomas W's Avatar
Just my opinion, but that carb looks out of place on there.
Thomas W is offline
post #22 of 28 (permalink) Old 03-15-2017, 02:20 PM
daveS53's Avatar
I have to agree. It's a shame to take a modern EFI engine and place a stone-age fuel system on it.
This is how it's done with an LS motor:
http://borowskirace.com/Hellfire29L.html
daveS53 is online now
post #23 of 28 (permalink) Old 03-15-2017, 06:14 PM Thread Starter
When you're making power like this, cams are going to be locked out regardless. Don't worry though, we are doing a carb'd vs EFI test.
My Build Thread:
post #24 of 28 (permalink) Old 03-15-2017, 07:20 PM
q4stix's Avatar
I see the caption under the oil pump says "Livernois Motorsports supplied a set of billet oil pump gears to replace the weak stockers. A new, Mustang oil pump is required on an F-150 engine."
I bought a billet oil pump gear for my build but didn't realize the pumps or pump housings were different. Anything you can point me to?
q4stix is offline
post #25 of 28 (permalink) Old 03-21-2017, 05:11 PM Thread Starter
The width of the gears are different between the two housings. Need to get a Mustang pump housing and pickup tube if you're using an F150 donor.
q4stix thanked this.
My Build Thread:
post #26 of 28 (permalink) Old 03-21-2017, 06:59 PM
q4stix's Avatar
I just did some checking. That applies to the 2011-2014 F-150s but thankfully Ford started using the same Mustang GT oil pump on the 2015+ F-150s (which is what I have).
Now back to your build and hopefully some insane dyno results
q4stix is offline
post #27 of 28 (permalink) Old 03-21-2017, 10:06 PM Thread Starter
Ok, good to know as well. Most people building engines right now are on the 11-14 cores.
Dyno is now the last Thurs-Fri of April. Still looking at that 1300-1400hp range.
My Build Thread:
post #28 of 28 (permalink) Old 04-25-2017, 06:11 PM Thread Starter
Mock up for the EFI test as well. Having an interference issue with the TPS to the blower pulley.
My Build Thread:
