Driver side foot box mods - FFCars.com : Factory Five Racing Discussion Forum
Old 10-19-2012, 09:58 AM   #1 (permalink)
After several months of inactivity due to shoulder surgery, I have resumed work. Although I have searched all sections of the forum, I haven't been able to find anything on modifying the driver side foot box on the engine side panel. I've installed a DOHC with 4-into-4 headers. Has anyone found a way to open this up?
My EEEs just don't fit between the sheetmetal and brake pedal.
Jim McGehee is offline   Reply With Quote
Old 10-19-2012, 10:22 AM   #2 (permalink)
4.6 SOHC T3650 Telorvek
d42davis's Avatar
Wilwood or donor pedals?
d42davis is offline   Reply With Quote
Old 10-19-2012, 10:49 AM   #3 (permalink)
tad240's Avatar
Making room for feet.
There is 1 post in this thread for the drivers engine panel expansion. Also, I have to wear driving shoes - size 13 just don't fit well with regular shoes.
Tad Rhodes
Whitakers, NC
tad240 is online now   Reply With Quote
Old 10-19-2012, 11:01 AM   #4 (permalink)
You didn't tell us whether you're working with a Mk3 or Mk4. I've done engine side footbox mods to both although they are equipped with Windsors. Armed with a tape measure and these ideas maybe you can make similar changes for your 4.6 car.
Like many other Mk3 owners I performed the well documented dv/dt "Rod Mod" on the right side, reversing the vertical bend then triangulating it both directions to the lower front and rear corners.
The Mk4 panel is shaped differently so I took a different approach by cutting a triangle out of it and bening up "pyramid" to provide some extra room around the throttle pedal.
Before, with the flat panel:
And after:
Hope that helps,
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 10-19-2012, 12:07 PM   #5 (permalink)
d42davis's Avatar
I have a narrowed mod motor foot box with Wilwood pedals. After 2 years of struggling, I cut about 3/8" off the right side of the brake pedal pad. I can wear any shoe now without interference.
Old 10-19-2012, 01:38 PM   #6 (permalink)
Perl's Avatar
I don’t have a lot of time to search. I hope this can get you started.
foot box mods
Perl is offline   Reply With Quote
Old 10-19-2012, 09:43 PM   #7 (permalink)
Footbox mod
I have the Complete Mk 3.1 kit (Wilwood pedal box) and DOHC with 4-into-4 headers. Engine is in plumbed and running, brake pedal has been trimmed as much as possible, RT go pedal.
Just eyeballin' it there is about 3/4-inch between the headers and the footbox sheetmetal near the throttle pedal.
Old 10-19-2012, 11:06 PM   #8 (permalink)
FFR Master Craftsman
Greg_M's Avatar
Jim,
If you need any help, let me know.
Miss August 2007
Miss December 2012
Miss TR6 June 2013
The blues brothers
