Coyote cooling fan - FFCars.com : Factory Five Racing Discussion Forum
Old 08-23-2012, 10:44 PM   #1 (permalink)
akpingel's Avatar
Coyote cooling fan
This is for installing the cooling fan using Factory Five's recommendation for coyote builds.
Is it just me or are the instructions from Factory Five not correct for wiring the cooling fan. To paraphrase, they say pull the fuse, pull the relay and tap in to the ORANGE wire (assuming Ron Francis wiring). I can't see how this makes sense. It seems like it should connect to the BLUE wire that goes to the fan. The orange wire goes to a switch for manual fan.
I wanted to start a topic so anyone using the F5 instructions is questioning this as well.
Anyone care to validate or disprove?
Alex
FFR # 7396
2004 VW R32
akpingel is offline   Reply With Quote
Old 08-24-2012, 02:28 AM   #2 (permalink)
Supermoderator
oldguy668's Avatar
The cooling fan is controlled by the ECU. There is an orange lead in the Coyote harness that originates in the Power Control Box.
Mark Twain
oldguy668 is online now   Reply With Quote
Old 08-24-2012, 02:58 AM   #3 (permalink)
akpingel's Avatar
Yea I have the ECU orange wire squared away. However in the RF wiring harness, the wire from the relay to the dash switch is orange. From the relay (to fuse) to fan motor is blue. I dont get why they are splicing in to the orange line and then pulling the relay and fuse?
FFR # 7396
2004 VW R32
Old 08-24-2012, 01:47 PM   #4 (permalink)
ClemsonS197's Avatar
Dont use the RF at all. Just connect the Ford Racing wires to the wires on the fan and the Ford ECU will do the rest.
MK3.1 - Under Construction
Coyote 5.0
Tremec 3650
Old 08-25-2012, 01:11 PM   #5 (permalink)
akpingel's Avatar
This is how I ran mine. I just want others to be aware that if they follow the instructions it doesnt look like the fan will work.
FFR # 7396
2004 VW R32
