Cracked oil filter adapter, Lincoln MKVIII - FFCars.com : Factory Five Racing Discussion Forum
Old 08-21-2012, 10:55 PM   #1 (permalink)
Jerry O's Avatar
I'm in a bit of a jam. My 4.6 has an oil leak due to a crack in the oil filter adapter . Engine is sitting in my 3.1 roadster. Lincoln wants an arm and a leg for a new part. Can anyone out there give me a lead on one, since the local bone yards are fresh out. Short of replacing the part, is there a suitable repair I could make, such as filling the offending threaded port with high temperature epoxy, or some such material, since this threaded port is no longer usable.
Jerry O is offline   Reply With Quote
Old 08-22-2012, 12:25 AM   #2 (permalink)
ldsman's Avatar
Go with after market one or use jb weld
robert mccabe
Old 08-22-2012, 01:47 AM   #3 (permalink)
mn12's Avatar
You sure it's a cracked adapter and not a bad gasket between it and the block?? They were notorious for leaking at about 100K. If it is cracked just look in a bone yard for one off a MarkVIII or a 4.6 Tbird
Type 65 Coupe 531
02 Modular Donor Build
Old 08-22-2012, 02:18 PM   #4 (permalink)
arm7419's Avatar
I removed this adapter from my 4.6 Aluminator engine. it's Black Chromed. You can have it if it helps.
chuck
Mklll, Roush 327AL, TKO600, 17" with IRS and Pin Drive, non doner, I-Squared, Tungsten/Satin Silver stripe,
RF GT40, Gulf Colors/SOLD
33 Hotrod #79 delivered 25 Jul 09, Mclean Wire Wheels, 4.6L Aluminator, Eaton S/C,ISIS, Velocity Yellow,
arm7419 is offline   Reply With Quote
Old 08-22-2012, 07:36 PM   #5 (permalink)
Jerry O's Avatar
Thanks Idsman, mn12, and Chuck. Chuck, how can I get in touch with you? This looks like an interesting alternative.
Jerry
Old 08-22-2012, 08:02 PM   #6 (permalink)
arm7419's Avatar
Jerry
I,m at 928 821 1091
Chuck
