Newbie looking for 4.6 DOHC/Mk VIII info - FFCars.com : Factory Five Racing Discussion Forum
Old 08-17-2012, 09:01 PM   #1 (permalink)
bonose's Avatar
Talking Newbie looking for 4.6 DOHC/Mk VIII info
Hi Folks,
First post so be gentle... Thinking of of Roadster build using Mk VIII donor. Have a few questions for the experts and not so experts.
Big Picture: Looking at econo build using Mk VIII donor. I've been reading a lot and am a little slow so...
1. Goals: 300-350 rwhp w/dohc 4.6L. Looks like the 96 Mk VIII offers better valve springs and more flexible (yet complicated) wiring harness. Wouold you all have issues w/ donor w/100k-125k miles-all other things being equal.
2. Anyone running stock Mk VIII dohc engine in FFR w/manual trans that has done dyno runs to verify the stock hp potential?
3. The Mk IRS works but need shorter axles and konis to replace the Mk shocks, correct? Any vendors/parts to make the axle swap?
4. What would be the most effective value for cost/hp gains? Seems that Mach 1 intake w/C heads are very popular upgrades but the intake swap is challenging. What about EFI parts/mods?
5. The FR500 heads look good but $$$. Anyone modding stock heads or even C heads and how much hp gain for the effort.
Gotta go fly now, so I'll check back and add more later. Have really enjoyed the FFR community and expertise and I really look for ward to some great inputs.
Ciao!!
Bonose
bonose is offline   Reply With Quote
Old 08-18-2012, 01:18 AM   #2 (permalink)
tad240's Avatar
Originally Posted by bonose View Post
Hi Folks,
Ciao!!
Bonose
First - Great to have you here. I think you'll find this to be one of the best forums out there so don't worry about questions. We all started where you are. And I'm a huge fan of the 4.6 DOHC; although, I think if I were to build another I'd probably lean towards the new Coyote if I could find one at a good price.
If you are set on a 4.6 DOHC, the Mark VIII is a good short block (Teksid) but I don't think you'll make your 300-350 rwhp goal without some work. The intake and heads will hurt you there. The stock rods will not handle boost too well so as long as you are staying NA, you'll be OK with that short block.
NA power for these is basically all in the heads and intake. As you noted, the C heads will be your best bet for power along with a 99-04 lower intake that was common on the Mach, Marauder, or Cobra (99-01). The C heads actually flow as well or better than the FR500's and are easily found for a decent price. A pair of 96-98 Cobra intake cams will provide a little improvement in power as well since they have a little more duration for a stock cam. Later stock cams have reduced duration and that is really what counts with a modular DOHC - valve lift is not as important. But there are other aftermarket cams out there that will improve power more. Long tube headers from FFR will help with power as well. C heads, 99-04 intake, stock cams, and long tubes should get you well over the 300 hump. Add aftermarket cams and a ported intake to the mix and you can be up in the 350+ range at the rear tires.
The MKVIII IRS is a good starting point but the differential is not a posi so you may want to install one during the swap. The shorter axles are included with the IRS kit from FFR but you'll have to swap them out with your donor assemblies. There are vendors that sell the entire axle assembly ready to install but that will cost you and will not be the most economical path since you stated you were doing a donor build. And the FFR IRS option includes the Koni rear shocks.
The fuel injection can be a little challenging at first but there are options available to get you up and running easily. Wirediet (Art Cuesta) is very popular so do a search on that. I used a Telorvek panel from The Detail Zone and it was straightforward and works well.
Do some research and searches here on the forum and you'll begin to get a plan together. And again, all questions are welcome. Best of luck on your build.
Tad Rhodes
Whitakers, NC
tad240 is offline   Reply With Quote
Old 08-18-2012, 02:30 AM   #3 (permalink)
bonose's Avatar
Tad,
Thanks for prompt reply. For clarification, if using the Mk IRS, you would need to modify the Mk axles, correct? Are any FFR IRS parts needed or can be ordered separately?
Any input for sources for C heads or are the usual suspects (ebay, etc.) the best. Will have more questions shortly.
Thanks again.
Bonose
Old 08-18-2012, 06:06 AM   #4 (permalink)
ldsman's Avatar
I just received my 2005 4.6 with transmission and programer. For about 4000.00 from the classifieds. I took a look at it today. If you want 350 hp I would go with the 2005+ setup. Welcome to the madness
robert mccabe
Old 08-18-2012, 01:54 PM   #5 (permalink)
RE63's Avatar
I cannot speak to the Limcoln directions directly.
I would suggest looking for a wrecked Mach1, The motors are rated from Ford at 305/0r 320, hvae big brakes and ABS. The make excellent roadsters. IF you have decided to go with a Lincoln and do not have a motor there is one for sale in the parts for sale section for short money from a very reputable forum and factory five friend.
RE63 is online now   Reply With Quote
Old 08-18-2012, 03:22 PM   #6 (permalink)
tad240's Avatar
I agree. The Mach 1 would be my choice as well if you're going 4.6 donor. You can source any additional IRS parts easily and economically if you choose that suspension instead of the solid set up. It'll have the C heads etc.
Tad Rhodes
Whitakers, NC
Old 08-18-2012, 03:32 PM   #7 (permalink)
In my opinion the stock MK VIII wiring harnesses are the least desireable choice for a FFR build due to their lengths (way too long) and the volume of wires (wires for EVERY amenity available at the time). Use a manual trans not the MK VIII auto trans (it really complicates things as the auto trans wires are in the dash harness instead of the computer harness like the Mustangs).
In my opinion the least complicated and efficient way to go is a path that has been discussed on the forum in the past by knowledgeable MK VIII builders and repeated here with several possible options -
Basically chose a 96-98 Mustang Cobra intake, engine harness, PCM / computer harness and PCM. The general rule of thumb is to match the year and Cobra model for all listed components although exprienced MK VIII builders sound like you can do a little mixing and matching if your knowledgeable about such things (I haven't worked in detail with any builder using this approach). Plus whatever other changes and upgrades needed or wanted.
Research and confirm your plan ahead of time so you don't paint yourself in a cornor and end up desperately wondering why your build won't start and what it's going to take to overcome that....
Art
Banner
Art Cuesta is offline   Reply With Quote
Old 08-19-2012, 02:03 AM   #8 (permalink)
bonose's Avatar
Thanks all for the input. Lots to think about. Good news the info is available with a bit of effort and ends up being a car!
Bonose
Old 08-20-2012, 11:02 PM   #9 (permalink)
ldsman's Avatar
The 2005 4.6 from mustang gt is about 340hp with hotrod cam upgrade
robert mccabe
