Best way to lift eingine - FFCars.com : Factory Five Racing Discussion Forum
Old 07-25-2012, 11:09 AM   #1 (permalink)
BIL1024's Avatar
So I got the engine out of the donor by wrapping chain around oil pan. Now whats the best way to put it in the engine bay ? There are no lift point that I see, its a 98 SOHC. Thanks
Saving for my next roadster. Donor shopping!
BIL1024 is online now   Reply With Quote
Old 07-25-2012, 12:27 PM   #2 (permalink)
stack's Avatar
There should be some bolt holes on the front and rear of the heads you can use. Find a metric bolt that fits and anchor your chain and lift away. Make sure you use good grade bolts. you will need metric ones
stack
FFR 65 Roadster
FFR 33 Hot Rod
stack is offline   Reply With Quote
Old 07-25-2012, 02:23 PM   #3 (permalink)
Banned
The connection should also be diagonal. From the driver side head to the rear passenger head.
Old 07-25-2012, 02:39 PM   #4 (permalink)
mn12's Avatar
I used an engine leveler with two chains going to the two alternator mount holes in the front and two on the rear of the heads
Type 65 Coupe 531
02 Modular Donor Build
mn12 is online now   Reply With Quote
Old 07-25-2012, 02:46 PM   #5 (permalink)
MPTech's Avatar
x2 mn12
an engine leveler will make your life MUCH easier for install
Licensed 4/24/13!! Wahoo!
Old 07-25-2012, 03:11 PM   #6 (permalink)
mn12's Avatar
something like this
Type 65 Coupe 531
Old 07-25-2012, 04:02 PM   #7 (permalink)
BIL1024's Avatar
Great thanks! Engine is fully assembled and makes it a bit harder to install, think removing the headers will help
Old 07-25-2012, 04:57 PM   #8 (permalink)
AC Bill's Avatar
It's definitely more awkward when the engine is fully assembled.
Some use the leveler chains attached to a plate bolted on, with the intake manifold off.
Certainly a little more wiggle room, with the exhaust headers off..
AC Bill is online now   Reply With Quote
Old 07-25-2012, 09:13 PM   #9 (permalink)
Mustang Man's Avatar
No way could I get our leveler on our Three-Valve with the plastic intake on. Pulled that and no problem...
HTH...
FFR5310RD
Mustang Man is online now   Reply With Quote
Old 07-25-2012, 09:46 PM   #10 (permalink)
Builder of FFR#5197
Starboy's Avatar
I just used heavy duty soft yellow straps and moved the chassis into position more so than the engine. Lifting the rear of the chassis made it easier for it to slide right in. By using straps I didn't have to remove any intake stuff. I used headers that I installed afterward, but it's best to remove exhaust manifold and you'll need to remove the PS reservoir.
Don
4.6L DOHC, IRS
Starboy is offline   Reply With Quote
Old 07-30-2012, 04:42 AM   #11 (permalink)
SuperCobra 1
Sergio's Avatar
I also used Heavy Duty Yellow straps, as Bob Zook taught me, he said he used to install Hemis in drag racers this way and never failed.
Removing it from the donor:
and installing it into the FFR Chassis:
SuperCobra 1
Sergio is offline   Reply With Quote
Old 08-01-2012, 05:16 AM   #12 (permalink)
Our solution:
mp41 is offline   Reply With Quote
