Radiator to use with coyote 5.0L V8 - FFCars.com : Factory Five Racing Discussion Forum
Old 07-10-2012, 06:08 PM   #1 (permalink)
During engine placement, damaged radiator slightly (made contact with engine crane). Probably involves 1 or 2 pathways for fluid across radiator. Trying to figure out how to handle:
1) new radiator from FFR ($299)
2) fill and check for leaks, if none call it good
3) other radiator? Which? Are there any other food options to increase cooling ability?
Thoughts?
Supergreekster is offline   Reply With Quote
Old 07-10-2012, 07:11 PM   #2 (permalink)
mn12's Avatar
How much damage? A photo might help. Personally I would pressure test it for leaks before I considered replacing
Type 65 Coupe 531
02 Modular Donor Build
Old 07-10-2012, 07:32 PM   #3 (permalink)
bhuff's Avatar
If the issue is just bent fins, then your concerns will be purely asthetics. The real question is, are the tubes damaged?
If a tube is damaged and the radiator is brass/copper, then you can often solder small holes up. I have used a regular soldering iron and solder to repair a radiator and it worked out great. If the radiator is aluminium and it leaks, then repair may not be possible, at least not relaibly and easily.
Brian's Build thread: http://www.ffcars.com/forums/17-fact...ld-thread.html
Daily Driver: Autumn Orange 97 GT
Previous Toy: 88 4cyl stang: 12.23@111mph Boosted, sprayed and alcholic
bhuff is offline   Reply With Quote
