Oil sender locations coyote
I have 4 senders:
1) oil pressure --> FFR Gauge
2) oil pressure --> coyote computer (called oil pressure switch in ford manual)
3) oil temp --> FFR Gauge
4) oil low sensor --> coyote computer (originally in stock oil pan, approx 2" down from flange)
I have moroso 4.25" oil pan
One bung on oil pan "high" (1" down from flange, front). Two bungs "low" (2" down from flange, 1 on each side) = same as stock (as measured from flange)
I am not including drain plug at "lowest point"
I was going to place oil low sender in 1 of "low" locations, same as (similar to) stock distance from flange.
I was going to place oil temp in other "low"
I think both oil pressure senders need to go in oil filter relocation circuit, after oil pump, prior to oil filter
But now I think oil low sender needs to be in "high" (front, 1" down from flange) location. HELP!!
Thoughts? (Help!!)
Reason: Left out detail.
