4.6 power - FFCars.com : Factory Five Racing Discussion Forum
Old 06-19-2012, 07:29 PM   #1 (permalink)
ldsman's Avatar
4.6 power
im looking at buying a 2001-2004 mustang gt motor and trans. i was looking at the numbers for stock. i was wondering if this motor is under powered for these cars for a steet mk4. my target is around 350 to 400 is what i was hoping for. but i liek the efi on the 4.6
robert mccabe
Old 06-19-2012, 09:01 PM   #2 (permalink)
Small Block Specialist
Venom_Injected's Avatar
Most street small bock windsor 302's are only putting down 300....
350 or 400hp is ALOT of power for a 2300# car.....
FUN FACTOR = HP / MASS
4.6L @ 350 - 400 HP will be just fine (specially if you can find a DOHC 4.6) and easily doable with a few go-fast parts...
LINK***PICTORIAL 302 EXPLORER/COBRA ENGINE REBUILD THREAD *** LINK
2005 F150 FX4 Flareside
2010 Fusion SEL
Venom_Injected is offline   Reply With Quote
Old 06-19-2012, 09:44 PM   #3 (permalink)
ldsman's Avatar
ive decided today to go the mod motor route. he will be lookign for a 2001-2004 motor for me.
robert mccabe
Old 06-20-2012, 01:54 AM   #4 (permalink)
Marty Prario's Avatar
Your horsepower numbers should be easy to reach with cams and heads. Even the stock motor hauls ass up to about 80mph. Above 80 is when the bigger horsepower numbers will really be noticed.
MKIII, 4.6 Sohc, 3 Link, Konis, FFR Lower Crtl Arms, 3.73 R & P, Champ Pan, GM Blue Granite Metallic W/Silver Strips by Bat Man
Marty Prario is online now   Reply With Quote
Old 06-20-2012, 02:41 AM   #5 (permalink)
33 Moderator
geoffav's Avatar
I'm using a dohc 4.6 from a Mach1 in my hot rod. I'm hoping for 350 at the wheels with modest bolt-on stuff. Stack efi, MS3 ecu, and no accessories to drive except the alternator. If I was using a sohc 4.6 I would not be able to use the stacks but I would leave it stock and use a turbo at 9psi or less. At 350rwhp my 2200 lb hot rod will be peppy enough.
Geoff
FFR 33 #037
FFR 33 Google Map Registry
FFR 33 Hot Rod on FACEBOOK
Old 06-23-2012, 01:39 PM   #6 (permalink)
Gator58's Avatar
I'm currently putting a 4.6l in mine from a '01 cobra (119k miles). I too went with the modular for quick-n-easy hp in a street driver.
I picked-up the Sean Hyland SA82 "How to Build Max-Performance 4.6-Liter Ford Engines" which is giving me some good insights on the internals. Seems the tricky thing about the 4.6 is making sure you find the correct parts for the correct engine setup. I'm almost to the point of cracking the engine open to check how much abuse it has taken - awaiting the gasket sets and arp stud sets to arrive.
I'm finding that the DOHC components are becoming a little harder to find, and tend to run into higher $$$$'s. It was a fairly tough decision to bite the bullet and dump more money into the engine for longevity and peace of mind over driving the rest of the life out of it as-is then replacing it. Being somewhat overshadowed by the 5.0 and now Coyote, I'm hedging that it might be collectible in time - but then my karma with collectibles has been that they don't gain value until *after* I unload them....
Good luck on your hunt!
Gator58 is offline   Reply With Quote
Old 06-23-2012, 04:42 PM   #7 (permalink)
ldsman's Avatar
I'm waiting on my motor it only has 7500 miles so I won't open it up. But ill clean it up and dress it up a little.
robert mccabe
