DOHC oil cooler (adapter) leak - FFCars.com : Factory Five Racing Discussion Forum
Old 01-12-2012, 02:13 PM   #1 (permalink)
Cobra79's Avatar
Anybody replace the o-rings and/or gasket seals in their DOHC oil cooler to stop an oil leak?
Where did you get the parts from and how much were they?
Research online shows them as dealer only and expensive (o-rings 25$, for special heat/oil resistant ones).
Some have sourced them via hardware stores using oil resistant/high temp ones. But I'm leery about that since it would be hard to insure the same spec's for material, size and hardness.
Any experience?
Current Stage
Kit ordered 1/25/12. Build school 2/10/12. Kit delivered 3/12/12!
The Plan
MK 4, '99 SVT DOHC donor, IRS, dark red w/ stripes.
Project starts
Fall 2011
Cobra79 is offline   Reply With Quote
Old 01-12-2012, 03:58 PM   #2 (permalink)
mn12's Avatar
I have never owned one with the oil cooler but have replaced a few of the gaskets between the block and filter housing. If it were me Imight consider getting a non cooled adapter and go that route
Type 65 Coupe 531
02 Modular Donor Build
Old 02-08-2012, 09:54 PM   #3 (permalink)
acth4347's Avatar
What a timely question. I am currently prepping my 98 DOHC for installation into my MarkIII and I have the same question about sourcing the O-rings. Anybody out there rebuild their oil cooler adapter? I did see a post about separating the oil/water cooler with one of these. I might consider using that..
Rcvd MK3.1 6/2011 with 3link
Using 98 DOHC w/ Vortech T45, PS, PB, ABS, AC
acth4347 is offline   Reply With Quote
Old 02-09-2012, 04:52 AM   #4 (permalink)
jcurti2's Avatar
I don't know about the o rings and gaskets, but the adapter/cooler is factory only and are very expensive. If you have one that you are not going to use put it up on ebay. I sold mine on svtperformance in about 5 minutes for far too little money.
I used a Moroso kit to split it out and used a regular oil cooler. Someone makes a preferred kit, but I can't remember for sure who. Maybe Ford Racing?
FFR 6928 RD Basic Kit w/pin drive IRS ordered 02/27/09 delivered 03/21/09
'03 Terminator Donor purchased 02/23/09 arrived 03/08/09 - Ported and Polished Eaton w/4# lower and 3.1 upper. 63# injectors, BAP, Dragon TB and Plenum.
jcurti2 is offline   Reply With Quote
Old 02-16-2012, 02:15 AM   #5 (permalink)
Cobra79's Avatar
I fixed my oil leak by simply tightening the oil cooler adapter stud. In my research I found high temp oil resistant Teflon coated silicon o-rings are the type used and will work if you get the right size. Source can be any machine parts supplier.
Current Stage
The Plan
Project starts
Fall 2011
