Not running hydroboost? - FFCars.com : Factory Five Racing Discussion Forum
Old 03-05-2008, 09:16 PM   #1 (permalink)
Builder
EZBuilder's Avatar
Anyone not running a PS pump?
I'm looking for a delete for the PS pump or an solution.
I've tried Summit, Modular Mustang and searched the net.
Has anyone tried just removing it and getting a shorter belt? Any interference?
Thanks.
4.6 DOHC SC "03"
Lampo
Mrk 3 Supercobra "03" T-56 IRS
View my Build progess at VenomXS.com !
EZBuilder is offline   Reply With Quote
Old 03-05-2008, 09:52 PM   #2 (permalink)
Builder
EZBuilder's Avatar
Also tried Kar Krafters. Although they do make a 4.6 PS delete, it won't fit the 03-04 Cobra so they say.
Lampo
Old 03-06-2008, 01:16 AM   #3 (permalink)
SuperCobra 1
Sergio's Avatar
I tought about it but decided against it, this engine weighs a lot more than the aluminum kind, remember that.
I guess you could use the Flaming River steering rack and non-powered brakes?
Let us know how that feels
SuperCobra 1
Sergio is offline   Reply With Quote
Old 03-06-2008, 02:50 AM   #4 (permalink)
henry beamer's Avatar
A friend of mine is a very good machinist & made an A/C eliminator bracket for my 2000 DOHC. He also made several other for other forum members. You can contact him directly at BGenewich@aol.com
Hank
s/n4428 MKIII, 2000 Cobra 4.6L DOHC crate, 3.27, IRS, under body exhaust, scoopless, cold air induction, Fordfun drop butt, hidden body mounts & trunk hinges, Kirkey seats, dual roll bars
henry beamer is offline   Reply With Quote
Old 03-06-2008, 07:45 PM   #5 (permalink)
Builder
EZBuilder's Avatar
Henry Beamer,
Are you driving it yet? How does it feel?
Lampo
Old 03-06-2008, 07:49 PM   #6 (permalink)
Builder
EZBuilder's Avatar
Sergio, have you pushed it hard on a track yet? How's the steering? Do you have a Bias valve in line? Twitchy?
Also, anyone, that is manual steering, how is it, to hard?
Power guys, how is it? bias valve? Twitchy?
Thanks, I guess I haven't made up my mind yet???
Lampo
Old 03-08-2008, 03:20 AM   #7 (permalink)
Lampo -
I have not driven mine yet, but I did drive my friend's 427 MKIII. It is a bit heavy at low speeds, but fine once you're under way. I believe that he's runing 1/8 front toe in which may make it a bit heavier. Tracks great with better off center rsponse than my Z3. I should add that at 6'1", 170 lbs and in my mid 50's I'll never be confused with Charles Atlas.
Hank
Old 03-08-2008, 06:11 PM   #8 (permalink)
Builder
EZBuilder's Avatar
Thanks Hank, and I've sent an inquiry to your PS pump delete machinist.
Thanks again
Lampo
