Has anybody paid to have the Technical Service Bulletin performed on their 3650?
It's a Ford warranty job, it wasn't done to my donor,before it became a donor.
and I imagine my car is out of warranty now.
the 1-2 shift is a little more snickity than I'd like, and that's what this TSB is for.
4.6 SOHC 3.55\'s 3 link PS/PB/AC 50 Ford FEZ red/08 Ford Creme Brulee stripe Stress relief with the turn of a key...
Never even heard of it. Can you post a link or something?
I had a puddle of yellow fluid under my 3650 when I pulled the car out for a spin yesterday. Poor driveline is just totally falling apart. I plan to eventually replace it from the pulleys to the driveshaft, and probably just junk everything that is in there now. Ah, to have the budget...
Cheers, John
2011 Dodge 2500 Cummins 6.7L - biodiesel-fueled daily driver JHETTO: 2001 VW Jetta TDI, intended as G3F donor, FOR SALE
Here's a post from a mustang board
First is TSB 04-15-6... This is for 99-2003 TR3650 trans:
ISSUE:
Some 2001-2003 Mustang vehicles, equipped with TR3650 5 speed manual transmission may exhibit a clash noise and/or a raspy (rough) feel on gear engagement during 1-2 or 2-3 shifts. The transmission may also exhibit a jump-out from 2nd and/or 3rd gear. The condition may be more pronounced when the transmission is colder than 40° F (5° C).
ACTION:
To service, install a Synchro Kit. The kit includes 2nd main shaft gear, 1-2 synchronizer assembly, 3rd main shaft gear, 3-4 synchronizer assembly, the 1-2 and 3-4 shift fork and rail assemblies, blocking rings and an oil fill level sticker. Add new transmission fluid and fill to the revised lower level. Refer to the following Service Procedure.
SERVICE PROCEDURE
NOTE: ALL COMPONENTS IN THE KIT ARE REVISED AND MUST BE REPLACED.
NOTE: BLOCKING RINGS MAY APPEAR DIFFERENT THAN THOSE BEING REMOVED FROM THE TRANSMISSION.
NOTE: REFER TO THE WORKSHOP MANUAL SECTION 308-03 TO AID IN THE FOLLOWING PROCEDURE.
Remove the transmission from the vehicle.
Disassemble the transmission.
Install all of the revised components included in kit 3R3Z-7124-AC.
Clean oil from area 26 mm (1") below the transmission fill plug (Figure 1) and install the oil fill sticker included in the kit.
Figure 1 - Article 04-15-6
NOTE: THIS TSB DOES NOT AUTHORIZE REPLACEMENT OF THE CLUTCH ASSEMBLY AND RELEASE BEARING FOR NORMAL WEAR. IF SUFFICIENTLY WORN, THE CUSTOMER MAY WISH TO HAVE THEM REPLACED AT THEIR EXPENSE. SOME DISCOLORATION AND LIGHT SCRATCHES ON THE FLYWHEEL OR PRESSURE PLATE ARE CONSIDERED NORMAL AND RESURFACING IS NOT REQUIRED.
Reinstall the transmission.
Fill the transmission with 3.0 liters (6.3 pints) of Motorcraft Mercon ATF (XT-2-QDX). The full fill level is approximately 19 mm (0.75") below the fill hole.
NOTE: SHIFT QUALITY MAY IMPROVE FURTHER WITH BREAK IN, APPROXIMATELY 644 KILOMETERS (400 MILES) OF DRIVING.
PART NUMBER PART NAME
3R3Z-7124-AC Synchro Kit
XT-2-QDX Mercon ATF
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
041506A Install Components Included In Kit (Includes Time To Remove And Install Transmission And Final Road Test) 5.6 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
7124 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Then there is a TSB for the 2004 ONLY!
ISSUE:
Some 2004 Mustang vehicles, equipped with the TR3650 5 speed manual transmission, may exhibit a clash or grind noise when shifting from 1st to 2nd gear. There may also be a loss of 2nd gear.
ACTION:
Order and install a synchronizer kit. The kit includes a 2nd main shaft gear, 1-2 synchronizer assembly, 1-2 shift fork and rail, synchro rings and cones and a new transmission fluid and fill label. Refer to the following Service Procedure.
SERVICE PROCEDURE
NOTE: ALL COMPONENTS IN THE KIT ARE REVISED AND MUST BE REPLACED. DO NOT INTERCHANGE.
Disassemble the transmission assembly.
Remove and replace ALL parts that are included in the kit.
Clean oil from area 1" (26 mm) below the transmission fill plug and install the oil fill sticker included in the kit (Figure 1).
Fill the transmission with 6.3 pints (3.0L) of Motorcraft Mercon® Multi-Purpose ATF (XT-2-QDX). The new full fill level is approximately 0.75" (19 mm) below the fill hole.
Figure 1 - Article 04-26-13
3R3Z-7124-BC Synchronizer Kit
XT-2-QDX Motorcraft Mercon® Multi-Purpose ATF
WARRANTY STATUS:
042613A 2004 Mustang: Install Components Included In Kit (Includes Time To Remove And Install Transmission And Final Road Test) 5.6 Hrs.
DEALER CODING
7124 42
Alot of people have been comming in here telling people it applys to the 04 also. But they are 2 diferent ones.
_____________________________
My donor is suitably afflicted... I mean covered, by this TSB. Had the local ford dealer run my VIN and it was not done to my car. So far my 1-2 and 2-3 shifts are smooth and haven't jumped out of 2 or 3. But, I only have 100 miles on it in the neighborhood go-carting. The local Ford dealer said mine was out of warranty (01 with 47K) and "couldn't help me" if it started later.
Wonder if Max at Five Star has handled any of these?
Max - are you out there reading this one? Let us know, and thanks.
If you can't laugh at yourself, you're too darn serious; enjoy life!!
Online Golden Rule: Never post anything online you wouldn't say to someone's face.
MKIII #5684, 2001 4.6 SOHC Bullitt Donor, Cobra Brakes, T3650, 3 link, FFR Konis F/R, Donor received 1/13/2006, Kit received 9/14/2006, First Start 7/28/2007, Candy Apple Red, Charcoal Silver and Black Stripes, Foose Nitrous Chrome Wheels, BFG KDW IIs, Graduated 9/7/2008, 5/19/2009 Dyno 307hp 347ftlb, 1/24/2010 Sold Barrett-Jackson $55k
Anyone got a clue what the puddle of dehydrated-urine-yellow fluid under my 3650 might be? I hadn't used it in six or eight weeks, and pulled it out of the garage this weekend. It was a bit of a mess under there.
Gotta replace that whole buggered driveline, I guess... Grrr...
Cheers, John
Did you get any moisture into the bell housing? Under what part of the transmission did it leak? Any pictures? Oily? Watery? Smell? Any stray cats in your garage?
I think we need to start up a collection for you to help you with rebuilding your driveline. Count me in for $20.
