PATS Transceiver Module? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 13 (permalink) Old 07-10-2006, 03:49 PM Thread Starter
petitm's Avatar
Angry
Does anyone have a picture of what this module looks like? I seem to have misplaced this during my donor disassembly. If I know what I am looking for, I might be able to plug it in and start my car.
Otherwise, I am going to have to go the ECU reprogram route which is why have asked my previously posted question.
I know, it's all good. Just a bump in the road. I would just like to hear it run.
Mark P. [img]graemlins/silver.gif[/img]
First build - MKIII w/3-link, 4.6L SOHC, PATS. Dreaming is free, building one costs a little more!
petitm is offline
post #2 of 13 (permalink) Old 07-10-2006, 04:48 PM
Perl's Avatar
Mark,
I’m guessing and it has been a while since I have looked at it but I think what you are talking about is the ring that goes around the key cylinder. It looks more like a trim ring but it has a couple of wires coming out of it with a plug at the end of the wires. If you don’t get a picture of it before I get home from work I will post it for you. There should be a picture of it in the manual.
Perl is offline
post #3 of 13 (permalink) Old 07-10-2006, 06:10 PM Thread Starter
petitm's Avatar
Perl,
I have the ring that goes around the key cylinder with the wires coming out of it. The Ford Wiring diagrams indicates that the C252 connector plugs into the "Passive anti-theft transceiver Module (15607)" that appears to be a box, not the ring.
The Ford dealership tech guy just said the ring is the transceiver module as you have indicated. He also indicated that the service manuals are written by several different companies and the names of the individual devices change to protect the innocent I presume. Therefore, I may have a none issue here. I will check the wiring harness going from that ring to the gauge cluster.
Thanks for the info.
Mark P.
petitm is offline
post #4 of 13 (permalink) Old 07-10-2006, 06:51 PM
Perl's Avatar
Mark,
There was no other box besides the gage pod that I know of. I just plugged the transceiver into the wiring harness and the wiring harness into the gage pod.
Perl is offline
post #5 of 13 (permalink) Old 07-11-2006, 01:36 AM Thread Starter
petitm's Avatar
Perl, you are correct. There is not other box. The shop manual does not exactly match what was installed. It's all good. Progress continues.
Thanks for the information.
Mark P.
petitm is offline
post #6 of 13 (permalink) Old 07-11-2006, 01:42 AM
Perl's Avatar
Oh and by the way when I said "I" I meant "WE" meaning Roger Stine.
Perl is offline
post #7 of 13 (permalink) Old 07-11-2006, 03:20 AM
Jeff, Art and I frequently recall that glorious day when you turned the key and your 4.6 simply started and idled. What a great sigh of relief followed by a cold refreshment. As I recall we later disabled your PATS. Before yours the only one we had running was Sergio's SUPERCOBRA.
All the best,
Roger
FFR 1225, Carbon, IRS, VPM bars, GT 40s.
Roger is offline
post #8 of 13 (permalink) Old 07-15-2006, 04:55 AM
yes there is a box on 1998 and under with pats and it is about 4x4s2 inches in 1999 and up it is part of your instrument cluster
Ricardo
mkIII, 3:55 solid axle, abs, ps, sohc with billitt intake and pi heads. Ricardo
Ricardo is offline
post #9 of 13 (permalink) Old 07-31-2006, 06:11 PM
El Conquestador
rednour1's Avatar
Ricardo is correct. My 1997 has a box for the Pats system.
What I have found is the manuals didn't change to match the cars completly.
Craig
"Growing older but not up"
FFR 5715, SOHC,
You can't buy class... You have to build it!
rednour1 is offline
post #10 of 13 (permalink) Old 07-31-2006, 08:47 PM
I Squared Engineering's Avatar
Snakeskin,
Give us a call if you need a chip. We will give you forum pricing on it...
Chris
I Squared Engineering is offline
post #11 of 13 (permalink) Old 08-01-2006, 04:29 PM Thread Starter
petitm's Avatar
Chris,
Thanks. My PATS issues have gone away. The car now starts and has been go-karted. No error codes thus far with the exception of the air bag light which will not be present when I do the gauge modifications.
But if I need to have a chip modified and burned, I will give you a call.
Mark P.
petitm is offline
post #12 of 13 (permalink) Old 08-01-2006, 08:04 PM
I have a picture of the F6ZZ-15607-A transceiver. I broke the 3 little wires when I removed the steering column. I had to buy another to get the car started. I don't know how to paste pictures on the forum. I would be glad to email pictures of this if I had your email address. I would also donate this transceiver to the forum to be used as a loaner for who ever needs it. I eliminated PATS from my car so it is sitting here in a box.
BOHNE4 is offline
post #13 of 13 (permalink) Old 10-29-2011, 08:50 PM
PATS Transceiver Module is the root cause of NO starts.
I replaced the PATS transceiver Module (Part Number 15607) and the car started like a charm.
javanes is offline
