Nothing got masked on my frame. what is the best way to remove the powder coating after it has been cured? I think I saw some where that it was suggested to use paint remover.
Any Ideas?
Everyone should learn to drive a Stick. Automatic transmissions allow to many people to drive that should never be behind the wheel!
Keep in mind that powder is baked on at 400F-450F. If you try paint remover, it may take a few attempts. I just removed some by burning it off with a propane torch. I don't know if you can do that due to the area you're talking about. A DA sander will work also. Start with rough paper tho. Powder coating is tough stuff. Good luck. Mike
A GOOD paint remover will help but you may still have to scrape also. I did both PLUS used a sand blaster to remove it from some suspension parts. Good luck.
Was the powdercoating done by a local vendor? If so take it back to them. They should have masked it in the first place. They have chemicals that will remove the powdercoating with just a little elbow grease.... maybe you can get some of it from them. If not, scraping and sandblasting may be needed. Good Luck...
Ken
FFR 4530 Completed 8/04 A modern twist on a classic car!...FPS 418W with stack injection, 453RWHP and 478#TQ, (so far) midshift Tremec 3550, painted black with candy red stripes by the BAT, Red Chrome 17" Cobra R's,Cobra brakes, VPM swaybars, CF dash with flamed billet bezel and Autometers, and a few other goodies!!
As far as sandblasting the area goes. Good luck! Part of the preping process is baking the part at 600F. This burns the powder so that it can be sand blasted easily. Blasting without burning will take forever...especially with a home compressor and blaster. You can try a heat gun also, but you need to blister the coating to get it off. Mike
Drummermike is right about the heat- Often I use a torch to quickly scorch the powder coat before sand blasting. Otherwise, you'll stand at the blaster all day trying to get it off(the p-coat, that is).
FFR2710: 400+RWHP, Vortech blown all Trick Flow 302, 3.27 IRS, Cobra R\'s, Tremec. Bodyman is finally ready for my car, Soon to be Lambo orange!
Several years ago, FFR was having major problems with their powdercoated frames - you just looked at it hard, and some of it would flake off.
I ended up taking my frame to a local powdercoater. He put the whole frame in the oven overnight to burn off the powdercoating, like DrummerMike said, and then sandblasted it. FFR refunded me my money for their powdercoating, but it cost me more money in the long run
John Hudson FFR 2513 My427SC.com
I don't think I want to take it back to the coater, he under charged me by a bunch.
The parts that need to be cleaned off, are all the bolts I welded on for ground studs and the Roll bar mounts. Nothing serious,
I might can get the studs with a wire wheel. I need a can of Aircraft remover, this is a good excuse to go get it.
