battery not getting charged- help - FFCars.com : Factory Five Racing Discussion Forum
Old 02-23-2004, 06:13 PM   #1 (permalink)
my battery is good, it holds charge from charger.
but if i run the car for 15 mins., car does not turn over. the red/charge light goes off when the car is started and my gauge shows plus or minus 13volts. is there some wire i did not connect?
what steps do i take to test battery,alternator, etc? when i charge the battery it holds charge as long as i don't run the car. [img]graemlins/blue2.gif[/img] [img]graemlins/blue2.gif[/img]
laldebot is offline
Old 02-23-2004, 06:26 PM   #2 (permalink)
20yrs of sleep, not all at the same time.
Rip Van Winkle's Avatar
The voltmeter should read 14v. If it’s reading around 12v, this is just the battery voltage and so nothing is coming thru from the alternator. You can get the alternator checked out at Autozone or you local parts store. If the alternator is OK then check your wiring. Sorry, I don’t have the color codes for the wire here at work, but there is a single wire to the starter solenoid, it has a fuse link (which could be your trouble) so check the voltage before and after the fuse link to the solenoid. You should be able to find the bad spot.
I had this same problem, and got stranded on the Fwy when the battery gave out. It was the fuse link for me. Good luck, hope this helps.
FFR4038K - Mark II completed 2007 in indigo blue, 5.0L with T5 and IRS.
Rip Van Winkle is offline
Old 02-23-2004, 06:32 PM   #3 (permalink)
Moderator Ad Nauseum
NAGA's Avatar
Hey Luis,
Weird.
Get the alternator checked out. Autozone will do it for free. Almost sounds like a polarity problem. Might be a diode out in the alternator. Like it's putting out voltage but not in the right direction. Very strange.
d.
Donald Rogus
NAGA is offline
Old 02-23-2004, 07:43 PM   #4 (permalink)
Mike Brasfield's Avatar
I had the same problem. It was the wire Rip Van Winkle mentioned. Check the continunity beteen the alt. and the relay. This is where the fuse link lives and it was a bad wire in my harness. Good luck.
Mesa Mike
Mike Brasfield is offline
Old 02-23-2004, 09:37 PM   #5 (permalink)
this happend to me. the low speed charge was not engauging. when I keep the rpms over 2000 it will charge and get over 14 volts. so if it is idiling for 15 minutes and the low speed charge is not working than your engine will not turn over because it is not charging. anyways goes to local parts store they can test it in the car or out
paulmcarlino is offline
Old 02-23-2004, 10:08 PM   #6 (permalink)
Horizon200's Avatar
Why does the green/red wire come to mind?
\"HABU\" FFR 3817 Redfire w/ Silver Stripes Stock build w/ 3:73\'s/Mass=Flo/Dual Roll Bars/Street Performers(finished 28 Feb 2004)
Horizon200 is online now
Old 02-24-2004, 12:20 AM   #7 (permalink)
HEY MIKE WHERE IS THAT R/G WIRE YOU ARE TALKING ABOUT? JUST RETURNED FROM AUTO STORE, MY ALTERNATOR WAS SHOT. DID NOT INSTALL YET, WILL SEE
TOMORROW IF ALL IS WELL.
laldebot is offline
