Bung Needed - FFCars.com : Factory Five Racing Discussion Forum
Old 09-11-2004, 04:12 AM   #1 (permalink)
TBullard's Avatar
I am using a 95 donor and I need to move the EGR tube from the drivers side header to the passenger side. Where can I purchase the bung that welds to the header that the EGR tube threads into? [img]graemlins/wrench.gif[/img]
FFR 5870, Coupe226, Coupe 031, FFR 5021, FFR 4430
TBullard is offline
Old 09-11-2004, 05:46 AM   #2 (permalink)
http://store.summitracing.com/defaul...=oxygen+sensor Summit has this, and I have seen it in a magazine, but just the fitting. Possibly Jegs. If you have the sensor, check the threads. If it is a common size, you may be able to just buy a nut. Thread gauge or take to hardware store. Luck, Glen
MarkII,347forgedstroker,AFR185heads,Typhoon,MSD6A, Torq-ThrustIIs Way too much hp!
Glen is offline
Old 09-11-2004, 05:52 AM   #3 (permalink)
Oh sorry. EGR, not HEGO. I messed up. Again, maybe you can check the threads and find something that will work. Another option is to cut off from driver's side and weld onto other. Will have to patch the hole, but this is certainly do-able if no other option is found. Bye, Glen
Glen is offline
Old 09-11-2004, 12:05 PM   #4 (permalink)
you can also just find a nut that is the right thread and weld it to the header. Beats having to wait for something to be shipped.
DarkWater is offline
Old 09-11-2004, 01:33 PM   #5 (permalink)
Sr FFR builder
Sinatra Fan's Avatar
Did you say Bung or Bong?
Doobie Doobie Do!!!
Sinatra Fan is offline
Old 09-11-2004, 02:21 PM   #6 (permalink)
Tom Mauldin's Avatar
That male bung is a metric thread. I had a hell of a time finding the fittings that were that size back when I needed to lengthen that egr tube to work on a 351w that I put in my '94 Mustang Cobra some years back. I sugguest you get anothe set of '94-'95 headers and cut it off of them.
Tom
www.texasvenom.com
It\'s not what you buy
It\'s what you build
Tom Mauldin is offline
Old 09-11-2004, 09:20 PM   #7 (permalink)
TBullard's Avatar
Bung is found [img]smile.gif[/img] I was able to cut the bung off the drivers side header with no problem so now I just need to have it welded on the pass. side and fill the hole in the drivers side.
TBullard is offline
